NationalInstrument.UI.dll NationalInstrument.UI.waveform.dll ?? please Help me . Aidez moi
i search NationalInstrument.UI.dll NationalInstrument.UI.waveform.dll on my hdd.
I have installed NI-Daqmx v8 and i dont find this dll?
also i have NationalInstruments.Common.dll, NationalInstruments.DAQmx.dll,... in the directory "C:\LabView 8.0\MeasurementStudioVS2003\DotNET\Assemblies\Current\".
I used VS2003 and the framework 1.1.
When this dll must be installed ? With other application or drivers?
Thanks for you answer but is Urgent for my job
Bonjour,
Je recherche les dll suivantes: NationalInstrument.UI.dll NationalInstrument.UI.waveform.dll car elles ne sont pas présentes sur mon disque dur. Pourtant j'ai installé les NI-Daqmw v8.
Cependant je trouve les suivantes NationalInstruments.Common.dll, NationalInstruments.DAQmx.dll,...  dans le répertoire "C:\LabView 8.0\MeasurementStudioVS2003\DotNET\Assemblies\Current\".
J'utilise VS2003 et le framework 1.1
Avec quel logiciel ou drivers ces dll peuvent être installées?
Merci pour votre réponse car j'en ai rapidement besoin pour mon travail.
(4,950 Views)
so, i have found this dll. I have installed measurement Studio Eval 7 and this package has deployed this 2 dll and other dll.
(4,948 Views)
This assembly is one of the UI libraries required for the Measurement Studio .NET UI libraries. If you are using just DAQmx, you do not require these libraries. The DAQmx .NET libraries are included with the DAQmx driver free of charge. The Measurement Studio libraries need to be purchased.
Bilal Durrani
NI
(4,939 Views)
