Need assistance setting WaveformGraph XAxis to time intervals starting at 0
I've been fumbling with a WaveformGraph in a finite aquisition program. It records 100 points at 10kHz.
I plot the data as below:
waveformGraph1.PlotWaveforms<double>(dataIn, new AnalogWaveformPlotOptions(AnalogWaveformPlotDisplayMode.Time, AnalogWaveformPlotScaleMode.Scaled));
But it doesn't plot in milliseconds or anything, it plots with major marks at "6.337e10", which, though some sleuthing, I think are "ticks" in the Timing property. I can't seem to find a way to convince it to use something else -- something more reasonable. When I try to set a different XAxis, it shifts and only shows me the select part of the dataset at that X-Range.
I hope this is descriptive enough; if you need clarification, please let me know. Thanks much.
(4,397 Views)
In the properties of the WaveformGraph (you can use Design mode for this if you want) you can edit the X-axis ranges and scaling. It sounds like you just have this set to an unfortunate value.
Steven Zittrower
http://www.ni.com/support
Message Edited by StevieZ on 06-04-2009 05:49 PM
(4,378 Views)
No matter what I set the x-axis for, it changes when I plot the waveform. If I change the range after plotting, it only shows me a fragment of the graph, corresponding to that time range.
This is the problem I am getting, when using the following code:
AnalogWaveformPlotOptions options = new AnalogWaveformPlotOptions(AnalogWaveformPlotDisplayMode.Time, AnalogWaveformPlotScaleMode.Raw);
waveformGraph1.PlotWaveforms<double>(dataIn, options);
As you can see, it gives me time in CPU ticks. While precise, it is of little help in deciphering the graph easily. I just need to convert "ticks" to "milliseconds", but have not yet found a way to do that.
(4,356 Views)
It looks like the LabelFormat of the Xaxis of the WaveformGraph is set to a numeric rather than a DateTime format, which is what you want. Changing that should fix issue.
Steven Zittrower
(4,346 Views)
