.Net(C#) dll pass 2D Array To LabView
Hello Expert:
  I have make a dll user Microsoft Visual C# .NET .and use usercontrol inherit datagrid for add function of dropdownlist in datagrid.
 It's can load into labview front panel operate no problem.
 I translate datagrid every cell to string[][] use property  in my dll class for labview to implement.
In labeview block diagram use dll property GetDataFromFirstRow is alight,
but use dll property GetDataFromTable is error.
(error message:The type of the source is 1-D of 1-D array of string.The type of the sink is 2D array of string)
this very trouble me,so i need help.
(7,478 Views)
Sorry I forget append my C# source
public string[] GetDataFromFirstRow
   get
    int iCol=dtData.Columns.Count;
    string[] sAr=new string[iCol];
    for(int i=0;i<iCol;i++)
     sAr[i]=dtData.Rows[0][i].ToString();
    return sAr;
  public string[][] GetDataFromTable
   get
    int iRow=dtData.Rows.Count;
    //Array sAr=new string[iRow][];
    //Array sAr=new ArrayList();
    string[][] sAr=new string[iRow][];
    for(int i=0;i<iRow;i++)
     sAr[i]=new string[iCol];
     for(int j=0;j<iCol;j++)
      sAr[i][j]=dtData.Rows[i][j].ToString();
    return sAr;
(7,476 Views)
I'm not sure of the problem you are having - I created the attached VI and C# source, where I built the corresonding solution in VS, and used the resulting assembly to obtain both a 1 and 2 dimensional array in the VI (MyFunction returns a 1D array, and MyFunction2 returns a 2D array).  Can you successfully do this as well?  I don't think I understand your question, but based on the title of the thread, perhaps this example of passing a 2D array of doubles from .NET to LabVIEW will help!
Best Regards,
JLS
PS - the assembly (dll file) could not be attached with the name/extension .dll, so I have renamed the extension to .txt - you should change the file name to .dll before opening the VI.  Also, after you rename the extension .txt file to .dll, make sure it is in the same directory as the VI.
Best,
JLS
Sixclear
(7,455 Views)
Thank  to foresignt Veteran:
        After reveived your sample file,I understand error reason.
     Labview don't  identify  double[] []  just double[,] .
     In other word,double[,] is array type and double[][] is object type.
     I change my  double[][]  type to double[,] is alight.
                                                     Thank you very mush.
(7,443 Views)
Excellent!
Best Regards,
JLS
Best,
JLS
Sixclear
(7,434 Views)
