Ni-DAQmx 9.4
I am converting an application from VS2008 c# .net 3.5 (that has worked for a few years)  to VS2010 c# .net4.0. When I run I am able to comunicate as expected to an NI-PCI 6509; however when I get to a point in code to set up an Analog channel for a NI-USB-6009 I get an error 'attempt to read or write to protected memory' I can't explain why. I also read on one of the NI forms that I needed to upgrade to NI-DAQmx 9.4 to be compatible with VS2010 and .net 4.0; Having done that the availble 'NationalInstruments.DAQmx.dll' calls for a version of 'NationalInstruments.Common.dll' 8.1.11.168 that does not exist from the install. Is this by design or are there other steps that need to be taken inorder to get NI-DAQmx 9.4 operable.
Loren
(4,583 Views)
Accepted by topic author Loren1
Hi Loren,
Have you tried to reinstall the .NET Framework (4.0) and then reinstalling the drivers? (You can also upgrade to the latest version of the driver -9.5- that you can find here).
steve.bm
AE | NI
(4,576 Views)
