No help or doc for .NET classes. MS7.0
Installed full version of MS7.0 (VC++). All the help links for the following .NET classes are dead. I can't find ANY doc's for these classes. Anyone know the trick?
Analysis .NET class library
Common .NET class library
DataSocket .NET class library
NI-488.2 .NET class library
NI-DAQmx .NET class library
NI-VISA .NET class library
(4,441 Views)
Where are you looking for the docs? There should be a shortcut under National Instruments/Measurement Studio in the Start menu that will launch just the Measurement Studio 7.0 help. Also, the Measurement Studio 7.0 help integrates into Visual Studio's documentation, so you should see Measurement Studio 7.0 help in the MSDN table of contents.
- Elton
(4,441 Views)
Elton,
Thanks for the help. ALL links to the subjects I mentioned are dead. As an example, opening
Measurement Studio->Measurement Studio Help from Visual Studio results in the following first page.
ms-help://MS.VSCC.2003/NI.MeasurementStudio/Main/static/MStudio_Start.html
The 2nd thru the 7th links are dead on the first page.
Measurement Studio Class Libraries
The Measurement Studio class libraries are designed specifically for engineers and scientists who build virtual instrumentation systems with Visual Basic .NET, Visual C#, or Visual C++ in Visual Studio .NET. With integrated libraries for acquiring, analyzing, and displaying data, Measurement Studio includes everything you need for building advanced measurement and automation applications.
Measurement Studio provides the following .NET libraries:
Analysis .NET class library <----- Dead Link
Common .NET class library <----- Dead Link
DataSocket .NET class library <----- Dead Link
NI-488.2 .NET class library <----- Dead Link
NI-DAQmx .NET class library <----- Dead Link
NI-VISA .NET class library <----- Dead Link
Thanks in advance for any help.
jim
(4,441 Views)
