OPC adding OPC Sever to C# application using using NI
My system is running C# application.
I would like to add OPC server capabilities (not Client) - I would like to serve other (external) OPC clients.
Is it possible to use NationalInstruments.Net for that? If yes - How (is there any example)? If not - is there any other NI tool that can be used for that?
(2,591 Views)
Hi kobbike,
NI has a software called NI OPC Servers for hosting data from PLCs and communicating with OPC clients over the OPC DA protocol. However, it is a standalone configuration-based software. So you would set it up and run it apart from your C# application. Since an OPC server has to know how to communicate with all sorts of different PLCs, it generally doesn't make sense to create your own server in your application.
Jordan
(2,568 Views)
