One shot & continuous samples trouble in VB.NET
I am using VB.NET 2003 with MS 8.0 ,
I have modified a National Instruments example in order to acquire one shot or continuous samples depending on the pressed button.I take one sample (from one of each three channels I have configured), then I pressed Continuous button in order to acquire in continuous mode and then if I stop the program with the stop button I get this error : Status code -200088. The click event for the stop button only checks if there's a task running and then disposed it. My problem is that everything goes well except when I disposed the continuous task.
I know it may be a stupid problem for an experienced programmer, so I attached my code hoping that someone can help me.
Thank's in advance.
Regards.
(3,489 Views)
Hi AINIA
   I've succesfully reproduce your error. What are you trying to accomplish? It seems you are reading 100 samples at a rate of 1000 samples per second, but you are only displaying the last one.
  The error seems to be produced because you are trying to close a task that is already closed. In order to do continous acquistion, try this link
http://sine.ni.com/apps/we/niepd_web_display.display_epd4?p_guid=C60E158A108C26A7E034080020E74861&p_node=174961
  There is also an on-line tutorial that uses USB-DAQ, but applies to your case
http://zone.ni.com/devzone/conceptd.nsf/webmain/C1EA00A64C9948BC86256FE800698BC3
Hope this helps
Javier Gutiérrez
NI Aplication Engineering
(3,456 Views)
