Only saves first and last data points to spreadsheet file
Hey,
I am sure this is an easy fix, but I can't seem to figure it out.  I am trying to interpolate values every 50 ms in a while loop and save the new values in a spreadsheet file.  Unfortunately, I only get two values saved, which I believe to be the first and last values. I would attach the vi, but it seems that I can only browse for an attachment, and I can't figure out how to actually attach it.  Maybe someone can clue me in on this too.  Thanks in advance,
Strass
(3,277 Views)
Since you attached a vi, it sounds like you're asking a LabVIEW question. If that's the case, you should post this question to the LabVIEW forum. That's the forum that the LabVIEW experts monitor and you'll get a much better answer to your question there.
- Elton
(3,271 Views)
Oops... I didn't mean to put this here.  Thanks anyways though.
(3,268 Views)
