Output internal trigger
we have a PCI-6111, which we use with analog trigger to measure two analog channel.
Now we need to trigger an external device based on our trigger event.
According to the manual we could configure pfi0/trig1as an output to reflect the initiation of the daq sequence.
Has anybody some sample code  how this is done.
Kevin Egle
(3,566 Views)
Hi Kevin,
What software are you useing? Did you look to the examples of the DAQmx driver? There you will find a lot of code ready to use.
TomBaum
(3,534 Views)
