PCIe-6321 - Unable to set Analog Input Reference Trigger to Analog Edge type
In our application, we are trying to detect the time that a projectile makes contact with a surface by monitoring the acceleration/vibration on the surface. I set up an analog input task with continuous sampling and tried to configure a trigger to detect an input signal above a threshold. This task consists of three input channels to monitor the accelerometer and a couple other inputs. I use an AnalogMultiChannelReader to periodically read the values of the channels to display to an operator.
The code looks vaguely as follows:
Create input channels (x3)
  • myTask.AIChannels.CreateVoltageChannel(pchannel, Name, AITerminalConfiguration.Rse, minVoltage, maxVoltage, AIVoltageUnits.Volts);
Configure task timing
  • myTask.Timing.ConfigureSampleClock("", sampleRate, SampleClockActiveEdge.Rising, SampleQuantityMode.ContinuousSamples);
Configure multi channel reader
  • multiReader = new AnalogMultiChannelReader(myTask.Stream);
Manually verify the task
  • myTask.Control(TaskAction.Verify);
Configure trigger
  • myTask.Triggers.ReferenceTrigger.ConfigureAnalogEdgeTrigger(channels[channel].Name, AnalogEdgeReferenceTriggerSlope.Rising, threshold, preTriggerSamples);
(Eventually) Retrieve timestamp of latest trigger event
  • public DateTime TriggerTimestamp { get => myTask.Triggers.ReferenceTrigger.Timestamp.ToDateTime(); }
Prior to configuring the trigger, I was able to read data from all three channels. I added the code for the trigger and now cannot load my application due to a -200077 error stating:
"Requested value is not a supported value for this property. The property value may be invalid because it conflicts with another property.
Property: NationalInstruments.DAQmx.ReferenceTrigger.Type
Requested Value: NationalInstruments.DAQmx.ReferenceTriggerType.AnalogEdge
Possible Values: NationalInstruments.DAQmx.ReferenceTriggerType.DigitalEdge, NationalInstruments.DAQmx.ReferenceTriggerType.None"
As far as I can tell from the documentation provided, any Reference Trigger should be able to be configured with an Analog Edge trigger.
Is this a limitation for this specific board that I could not find in the documentation? Or is there another method to configure the channels/task/trigger? Any help or ideas are appreciated. Thanks!
Message 1 of 1
(1,182 Views)
