Peak Detector for C# in Visual Studio 2008
I have to detect the Peaks of a signal in a ScatterGraph. I have the signal created, in this case, the following signal:
double[] signal = new double[3200];
double[] x = new double[3200];
Random aleatorio = new Random();
for (int i=0; i< 3200; i++)
     signal[i] = 0.74 * aleatorio.Next(5);
     x[i] = i;
scatterPlot1.PlotXY(x,signal);
With this Example, I detect the Peaks with the following code:
PeakPolarity peakPolarity = PeakPolarity.Peaks;
PeakDetector pkd = new PeakDetector(0.5, 3, peakPolarity);
pkd.Detect(this.signal, false, out this.amplitudesPeak, out this.locationsPeak, out secondDerivativesPeak);
scatterPlotPeaks.PlotXY(locationsPeak, amplitudesPeak);
Where this.signal is the previous signal which I have generated.
The problem is:  The Peaks which are plotting in the Graph don't coincide with the real peaks of this.signal.
¿Why??
(5,908 Views)
Could you post the full project?
Thanks!
(5,850 Views)
Just use "Reset" with the same parameters before any call to "Detect".
// loop
pkd.Reset(
Regards
Iñaki Gauna
(4,793 Views)
