Performance problem with IntensityGraph Plot()
I'm using IntensityGraph from Measurement Studio 2010, it is working fine. The problem is, it is taking a huge amount of CPU (like 35-40% of my PC's total CPU) while active. Most of the time is spent in the Plot(double[,]) function. Is there any way to improve the performance, e.g. override or re-implement some part of the component? Any other potential fix or workaround from NI?  Thanks.
(4,785 Views)
On closer inspection, it appears that the main culprit is in the painting, not plotting. If I move another window in front of the intensity graph window, or if I override the IntensityGraph.OnPaint() method and replace it with empty code, CPU loading goes back down. What can be done to make this OnPaint() method less of a CPU hog? Thanks.
(4,782 Views)
jble,
It sounds like OnPaint() might be called more than necessary in your case. There could be a variety of reasons why that is happening. Do you have any other UI tools overlapping with part of the Intensity Graph? This is a common problem that is often overlooked. Overlapping objects cause more draw operations than would otherwise be performed.
Cheers,
KyleP
(4,776 Views)
