Pixel position of a data point
Hello all,
I would like to know where the mouse position location of a data point is relative to the graph. Basically, the reverse action of this person's post:
WPF graph display point value on hover
http://forums.ni.com/t5/Measurement-Studio-for-NET/WPF-graph-display-point-value-on-hover/m-p/243395...
Instead of getting data point,  would like the mouse position. I am overlaying shapes over the graph and would like to know where a specific point in the graph is in pixel location coordinates.
Thank you.
Message 1 of 10
(4,918 Views)
Accepted by topic author gabe0
From your question, I assume you have a data value you want to translate (as opposed to a mouse event args, which already has a GetPosition method).
You can use the DataToScreen method to get a screen position within the plot area, and use the DesiredPlotAreaMargin to offset that screen position to reference the outer graph control (i.e. point.X += margin.Left; point.Y += margin.Top).
You can also use the DataToRelative method to get a relative position for a data point, and then position an object in the Children collection (much like a PointAnnotation😞
XAML
xmlns:ni="http://schemas.ni.com/controls/2009/xaml/presentation"
xmlns:niPrimitives="http://schemas.ni.com/controls/2009/xaml/presentation/primitives"
<ni:Graph x:Name="graph">
    <ni:Graph.Children>
        <Ellipse x:Name="dataMarker"
                 Width="10"
                 Height="10"
                 Stroke="Black"
                 StrokeThickness="2"
                 niPrimitives:RelativePanel.RelativeHorizontalAlignment="Center"
                 niPrimitives:RelativePanel.RelativeVerticalAlignment="Center"
    </ni:Graph.Children>
</ni:Graph>
Code
Point relative = graph.DataToRelative( dataValue );
RelativePanel.SetRelativeHorizontalPosition( dataMarker, relative.X );
RelativePanel.SetRelativeVerticalPosition( dataMarker, relative.Y );
~ Paul H
Message 2 of 10
(4,902 Views)
Thank you for the quick reply! One last question, how do I set the PlotAreaMargins?
Message 3 of 10
(4,854 Views)
If you want to set the plot area margin, instead of just reading the desired value, you can use the PlotAreaMargin property.
~ Paul H
Message 4 of 10
(4,850 Views)
Are the plot area margins the distance from the bounds of a plot to the edge of each Axes? I'm looking to get that offset value from the graph.
Gabe
Message 5 of 10
(4,847 Views)
There is a single margin for the "plot area", which is the central part of the graph where data is drawn. In addition to the plot area, the graph allocates space around the plot area to display the coordinate axes. The DesiredPlotAreaMargin property indicates the desired size for all the axes, but you can override the desired size by specifying an explicit PlotAreaMargin.
Could you explain what you mean by "from the bounds of a plot to the edge of each axis"? Are you referring to the "plot area", or to the data values for an individual plot? Could you describe how you are using the margin value?
~ Paul H
Message 6 of 10
(4,844 Views)
The space around the plot area to display coordinate axes is what I mean by from the bounds of a plot to the edge of each axes. So you did answer my question, thank you. So, where can I set the plot area margin because I don't see the property anywhere.
Thanks.
Message 7 of 10
(4,839 Views)
PlotAreaMargin is a property of the graph (i.e. "<ni:Graph PlotAreaMargin="42" ...>" in XAML, or "graph.PlotAreaMargin = new Thickness( 42 );" in code).
~ Paul H
Message 8 of 10
(4,832 Views)
Okay, I'm using ni:Graph and it doesn't show up. I'm using MS2013, is this a new feature?
Thanks.
Message 9 of 10
(4,830 Views)
Ah, yes: I believe this was added in Measurement Studio 2015.
~ Paul H
Message 10 of 10
(4,828 Views)
