PlotXY Axis Time Offset
I am graphing time based data on a PlotXY graph from a Database which works great.  The problem I am having is that the data in the database is in GMT and the user can change the time zone.  I can make the time adjustment everywhere else on the webpage that this is used on except on the graphs.  Can someone help me with this?
(3,779 Views)
Hi jharwood,
Can you provide more information about your x-axis time data?  If you are using the function, myXYGraph.PlotXY(dataX, dataY);, you could add (or subtract) a constant to all data in the dataX array to change to the GMT time zone.  How to add a constant and the value of that constant would be dependant of the time data you are passing to the x-axis.
Jessica
Product Support Engineer
(3,764 Views)
I was able to figure out the solution to my problem.  What I did was I made the date conversion in the SQL Query by doing a dateadd function.
(3,757 Views)
