Plotting AnalogWaveformCollection<double> data onto the WaveformGraph in Windows Form
Hi Everyone,
I have list of values of type AnalogWaveformCollection<double> and I wish to plot these values onto a graph. According to some sources from the website I used the following method inorder to do but I get an error which says :  Type arguments cannot be inferred from the usage. Try specifying them explicitly.
Here is the code:
void StartAcquisition()
            PrecisionTimeSpan timeout = new PrecisionTimeSpan(5.0);
            AnalogWaveformCollection<double> waveforms = null;
            try
                InitializeSession();
                scopeSession.Measurement.AutoSetup();
                long recordLength = scopeSession.Acquisition.RecordLength;
                double sampleRate = scopeSession.Acquisition.SampleRate;
                waveforms = scopeSession.Channels[ChannelName].Measurement.Read(timeout, recordLength, waveforms);
                //waveformGraph1.PlotWaveforms(waveforms);  // error
Can anyone please  help ?
Priyanka
Message 1 of 16
(7,728 Views)
Hi, Priyanka
Can you help us understand your code better? As far as I understand, your code should not work for a different reason: PlotWaveforms expects an array of AnalogWaveform<T> objects, and you're providing it with an AnalogWaveformCollection<T>. I wrote a quick snippet to illustrate my point better:
// Can be plotted using PlotWaveform(s).
var singleWaveform = AnalogWaveform<double>.FromArray1D(new double[] { 1.0, 2.0, 3.0, 4.0, 5.0, 4.0, 3.0, 2.0, 1.0 });
var waveformArray = new AnalogWaveform<double>[] { singleWaveform, singleWaveform };
// Cannot be plotted using PlotWaveform(s).
var waveformCollection = new AnalogWaveformCollection<double>();
_waveformGraph.PlotWaveform<double>(singleWaveform);
_waveformGraph.PlotWaveforms<double>(waveformArray);
// This shouldn't work because PlotWaveforms expects an array of AnalogWaveform<T> objects.
// _waveformGraph.PlotWaveforms<double>(waveformCollection);
Can you post an image of the exception you're seeing?
Daniel Dorroh
Message 3 of 16
(7,622 Views)
Thank you Daniel. As per your suggestion, I have made sure that I plot AnalogWaveform<double> data. Here is the error free code:
        static void PlotWaveformsOnGraph(AnalogWaveformCollection<double> waveforms)
            AnalogWaveform<double> SampledWaves = null ;
            double[] waves = new double[waveforms[0].SampleCount];
            int count = 0;
            for (int row = 0; row < waveforms[0].SampleCount; row++)
                foreach (AnalogWaveform<double> waveform in waveforms)
                    waves[count] = waveform.Samples[row].Value;
                    count++;
            MainWindow main = new MainWindow();
            SampledWaves = AnalogWaveform<double>.FromArray1D(waves);
            main.waveformGraph.PlotWaveform<double>(SampledWaves);
But , even after successful execution, I do not see the Waveform plotted on the graph. The graph is empty without any waves. What could be the reason.? Any suggestions?
Message 4 of 16
(7,596 Views)
Hi, Priyanka
I think you can do what you are trying to do in a simpler way. Please see the following snippet:
    List<AnalogWaveform<double>> waveformsList = new List<AnalogWaveform<double>>(waveforms);
    waveformGraph.PlotWaveforms(waveformsList.ToArray());
Daniel Dorroh
Message 5 of 16
(7,581 Views)
Awesome !! thank you for making it compact. But I still don see the graph on screen. Ideally when I click on "Start Analysis" Button, the waveform should appear in the area. Please refer to the screenshot attached with this message. I really appreciate your time and inputs. Please help me with this.
Message 6 of 16
(7,539 Views)
If you put a breakpoint at the start of the PlotWaveformsOnGraph function, does the waveforms parameter contain waveforms? How do you know the data is making it to the PlotWaveforms method?
Daniel Dorroh
Message 7 of 16
(7,531 Views)
Yes, Daniel. I also verified it by printing the values onto the console and I did get the values :
List<AnalogWaveform<double>> waveformList = new List <AnalogWaveform<double>>(waveforms);
main.waveformGraph.PlotWaveforms(waveformList.ToArray());
       foreach (AnalogWaveform<double> wave in waveformList)
            Console.WriteLine("samplessss"+wave.Samples[row].Value.ToString());
output:
samplessss---->1.48847971245414
samplessss---->1.49389002792304
samplessss---->1.49253744905582
samplessss---->1.4918611596222
samplessss---->1.49118487018859
samplessss---->1.48780342302052
samplessss---->1.4864508441533
samplessss---->1.48983229132136
samplessss---->-1.51627424109029
samplessss---->-1.51221650448861
samplessss---->-1.50612989958609
samplessss---->-1.50951134675415
samplessss---->-1.51086392562138
samplessss---->-1.51356908335583
samplessss---->-1.51289279392222
samplessss---->-1.51018763618777
n so on......
I don't know why its not plotting it on the graph.
Message 8 of 16
(7,517 Views)
How do you have your graph configured? Can you post any code you've written that configures the graph and the contents of InitializeComponent? Are you doing any plot configuration in code aside from PlotWaveforms?
Daniel Dorroh
Message 9 of 16
(7,504 Views)
Yes Daniel,
//some code
sampledWaves.ScaleMode = WaveformScaleMode.CreateLinearMode(2, 0);
main.xAxis.MajorDivisions.LabelFormat = new FormatString(FormatStringMode.Numeric, "G5");
sampledWaves.Timing = WaveformTiming.CreateWithRegularInterval(main.waveformPlot.DefaultTiming.SampleInterval);
main.waveformGraph.PlotWaveform(sampledWaves, plotOptions);
public AnalogWaveformPlotOptions initialPlotConfiguration(){
plotOptions = new AnalogWaveformPlotOptions(AnalogWaveformPlotDisplayMode.Samples, AnalogWaveformPlotScaleMode.Raw);
return plotOptions;
public AnalogWaveform<double> PlotWaveform(AnalogWaveformCollection<double> waveforms)
 double[] waves = new double[waveforms[0].SampleCount];int count = 0;
count++;
AnalogWaveform<double> SampledWaves = AnalogWaveform<double>.FromArray1D(waves);
SampledWaves.ScaleMode = WaveformScaleMode.CreateLinearMode(2, 0);
return SampledWaves;
Message 10 of 16
(7,457 Views)
