Polar to Complex
I am converting a vector (polar) to complex and then back.  The magnitudes are correct but the angles are wrong.  Any ideas?
I am assuming that theta is in degrees.  Wrong assumption?  Is it radians?
(3,550 Views)
Hi Ronster,
The theta value is always in radians in all our comples functions. Whenever you use a function if you choose to display Context Help and then go to Detailed Help for that function it will show you the data types for the terminals. Hope this helps.
Ipshita C.
(3,531 Views)
