Problem adding plots to the graph dynamically
I'm trying to add/remove plots to a  graph dynamically but are geting the error below. What am i doing wrong? Could you please give me an example of how i should do this? I'm using MS 8.0.1 and VS 2005 C#.
My code snippets:
Adding a plot:
timestampGraph.Plots.Add(new NationalInstruments.UI.WaveformPlot());
Appending plot data:
timestampGraph.Plots[plotIndex].PlotYAppend(timestampDiff);
Clearing plot data:
timestampGraph.Plots[plots.FindIndex(delegate(TimestampPlotInfo p) { return (p.source == source); })].ClearData();
Exception:
+  $exception {"Collection was modified; enumeration operation may not execute."} System.Exception {System.InvalidOperationException}
Callstack:
  StackTrace "   at System.Collections.Hashtable.HashtableEnumerator.MoveNext()\r\n   at NationalInstruments.UI.Internal.dv.a(ComponentDrawArgsInternal A_0, RectangleF[] A_1)\r\n   at NationalInstruments.UI.Internal.dv.b(ComponentDrawArgsInternal A_0)\r\n   at NationalInstruments.Restricted.ControlElement.a(ComponentDrawArgsInternal A_0, Rectangle A_1, Boolean A_2)\r\n   at NationalInstruments.Restricted.ControlElement.DrawChildren(ComponentDrawArgsInternal args, Rectangle clipRectangle)\r\n   at NationalInstruments.Restricted.ControlElement.a(ComponentDrawArgsInternal A_0, Rectangle A_1, Boolean A_2)\r\n   at NationalInstruments.Restricted.ControlElement.DrawChildren(ComponentDrawArgsInternal args, Rectangle clipRectangle)\r\n   at NationalInstruments.Restricted.ControlElement.a(ComponentDrawArgsInternal A_0, Rectangle A_1, Boolean A_2)\r\n   at NationalInstruments.Restricted.ControlElement.a(ComponentDrawArgsInternal A_0, Rectangle A_1)\r\n   at NationalInstruments.Restricted.ControlElement.Paint(PaintEventArgs e)\r\n   at NationalInstruments.UI.WindowsForms.ControlBase.OnPaint(PaintEventArgs e)\r\n   at System.Windows.Forms.Control.PaintWithErrorHandling(PaintEventArgs e, Int16 layer, Boolean disposeEventArgs)\r\n   at System.Windows.Forms.Control.WmPaint(Message& m)\r\n   at System.Windows.Forms.Control.WndProc(Message& m)\r\n   at System.Windows.Forms.Control.ControlNativeWindow.OnMessage(Message& m)\r\n   at System.Windows.Forms.Control.ControlNativeWindow.WndProc(Message& m)\r\n   at System.Windows.Forms.NativeWindow.DebuggableCallback(IntPtr hWnd, Int32 msg, IntPtr wparam, IntPtr lparam)\r\n   at System.Windows.Forms.UnsafeNativeMethods.DispatchMessageW(MSG& msg)\r\n   at System.Windows.Forms.Application.ComponentManager.System.Windows.Forms.UnsafeNativeMethods.IMsoComponentManager.FPushMessageLoop(Int32 dwComponentID, Int32 reason, Int32 pvLoopData)\r\n   at System.Windows.Forms.Application.ThreadContext.RunMessageLoopInner(Int32 reason, ApplicationContext context)\r\n   at System.Windows.Forms.Application.ThreadContext.RunMessageLoop(Int32 reason, ApplicationContext context)\r\n   at System.Windows.Forms.Application.Run(Form mainForm)\r\n   at AdrRecorder2Client.Program.Main() in C:\\Project\\Autoliv\\AdrRecorder2Client\\Applications\\AdrRecorder2Client\\Program.cs:line 19" string
Ps. It's quite annoying that you can preview the post, push the back button to edit something and all that you have written is wiped! Ds.
(3,986 Views)
In order to make a workaround i tried creating several static plots and initialize them as non-visual and then make he ones i need to use viual as i go along. The puzzling thing is that i actually got the same error here as well, it was able to plot for a few seconds and then the exception was raised.
A stupid question but the plot function is thread-safe right???
(3,971 Views)
Perhaps the problem is that you're accessing the graph from a thread other than that which it was created on - look at the places where you access the graph and see if any could be from a different thread (e.g., as a result of a network callback, or unsychronized timer callback).
(3,947 Views)
