Problem obfuscating DAQmx 8.0 with Dotfuscator
We're getting an error when running Preemptive's Dotfuscator product against our .NET 1.1 application, to which we recently incorporated DAQmx 8.0 (we did not get this error until we added DAQmx to our app).
The error we get is: "Error encountered while loading module (C:\PROJECTS\AscendGeo\USM\bin\NationalInstruments.DAQmx.dll). Index was outside the bounds of the array."
Preemptive has requested that we send them the DLL that is causing the failure (ie, DAQmx 8.0).
---> Do we have National Instruments' permission to send that DLL to Preemptive?
(obviously, please answer only if you're an NI employee with the authority to permit/deny this).
DT
(3,685 Views)
Hello
The DAQmx driver is a freely downloadable driver and the NationalInstruments.DAQmx.dll assembly is part of this driver.
You are welcome to pass on the DLL to Preemptive for further investigation. It would be great if you could share the results of the investigation with the forum in case others are running into this problem as well.
Message Edited by bilalD on 03-17-2006 05:21 PM
Bilal Durrani
NI
(3,677 Views)
