Problems with BurstMode 32 bits in Nidaqmx
Hi:
I am working in a transfer by burst mode, i must to send a signal over the channel ACK2 (PFI5) for recieve data over the port0 (32 bits) at a 20Mhz frequency. For that i create two task, one for adquire the data by burst handshaking mode and one for write '1' digital over PFI5, the problem is that when i run tha program with port0_32 (32 bits), it says me " DAQmx ERROR End the program, press ENTER key to quit", but when i run with port0_16, it runs ok.
I'm working with a PCI 6534 and NIDAQmx library.
Here is my code. Thanks.
int main(void)
//CREATE TASK BurstMode
DAQmxErrChk (DAQmxCreateTask("",&taskHandle));
DAQmxErrChk (DAQmxCreateDIChan(taskHandle,channel,"",DAQmx_Val_ChanForAllLines));DAQmxErrChk (DAQmxCfgSampClkTiming(taskHandle,
"/Dev1/PFI4",200000000.0,DAQmx_Val_Rising,DAQmx_Val_ContSamps,SizeOfData));DAQmxErrChk (DAQmxCfgBurstHandshakingTimingExportClock(taskHandle,DAQmx_Val_ContSamps,SizeOfData,20000000.0,"/Dev1/PFI4",DAQmx_Val_ActiveHigh,DAQmx_Val_Low,DAQmx_Val_ActiveHigh));
DAQmxErrChk (DAQmxGetTaskAttribute(taskHandle,DAQmx_Task_NumChans,&numChannels));
DAQmxErrChk (DAQmxRegisterEveryNSamplesEvent(taskHandle,DAQmx_Val_Acquired_Into_Buffer,SizeOfData,0,NIDAQEvent,NULL));
DAQmxSetBufInputBufSize(taskHandle, SizeOfData);
data=malloc(SizeOfData*numChannels*
sizeof(uInt32));
if( data==NULL ) {printf (
"Error","Not enough memory\n"); goto Error2;
//CREATE TASK WRITE
DAQmxErrChk (DAQmxCreateTask("",&taskHandleWritten));DAQmxErrChk (DAQmxCreateDOChan(taskHandleWritten,"/Dev1/PFI5","",DAQmx_Val_ChanForAllLines));
/*/ Start BurstMode/*********************************************/
DAQmxErrChk(DAQmxStartTask(taskHandle));
Sleep(100);
/*/ Start TaskWrite/*********************************************/
DAQmxErrChk(DAQmxStartTask(taskHandleWritten));
DAQmxErrChk(DAQmxWriteDigitalLines(taskHandleWritten,1,1,10.0,DAQmx_Val_GroupByChannel,&DataACK2_1,NULL,NULL));
DAQmxStopTask(taskHandleWritten);
printf(
"Generating digital output continuously. Press any key to interrupt\n"); while( !_kbhit() ) {
Sleep(100);
_getch();
Error2:
if( DAQmxFailed(error) )
DAQmxGetExtendedErrorInfo(errBuff,2048); // informa el tipo de error
 if( taskHandle!=0 ) {
 /*/ DAQmx Stop Code
DAQmxStopTask(taskHandle);
DAQmxClearTask(taskHandle);
DAQmxClearTask(taskHandleWritten);
if (data)
free (data);
printf("DAQmx Error: %s\n",errBuff);printf(
"End of program, press Enter key to quit\n");}
getchar();
return 0;
Message 1 of 1
(3,436 Views)
