Programming PXI-4110 with C#.NET
Trying to program a PXI-4110 with C#.NET.  Used the following code:
IviSessionFactoryClass
sf = new IviSessionFactoryClass();
pxi4110 = (
IIviDCPwr)sf.CreateDriver("PXI1Slot13");
Gives error of not having Prog ID not set correctly.  Tried putting in a value in MAX and received a Prog ID not registered.
Any examples with C# would be great.
It is working under CVI.
(5,938 Views)
BobbyJ,
Attached is a wrapper class created using Measurement Studio for the NI-4110 driver. It is not tested for full functionality but gives you the same functions as the text-based shipping examples.
Abhinav T.
Abhinav T.
Applications Engineering
National Instruments India
LabVIEW Introduction Course - Six Hours
Getting Started with NI-DAQmx
Measurement Fundamentals
(5,919 Views)
