Query a Device for Allowable TerminalConfiguration values
You can read/write the TerminalConfiguration property in a channel in a task. But how do you query a device for which TerminalConfiguration values it supports? For example, most devices do not support Pseudodifferential and C# throws an exception if you accidentally select it in the list of AITerminalConfiguration values. Searched the docs, maybe I just missed it. Thanks.
(5,446 Views)
Hi BloodCleaner
Here you have a table that lists the default terminal configuration of NI Hardware, as you said few hardware supports pseudodifferential configuration, at the end of this article you can find which families supports this terminal configuration.
regards
Chris S.
(5,420 Views)
