ReadMultiSamples from MultiChannels - old values arrive
Hi!
I have a problem with the program which is included in the post:
I am using  DAQMx with my PCI-MIO-16E-1 card.
I just want to read in some voltages from all AI in a single task.
In my constructor I have declared the things. (look at the program code).
The only problem is, if I run the method "getAI" in a loop, I get old values, so If I measure with the multimeter and increase the voltage, on my pc it only shows realtime values 1-5sec later!
why that?
I have 200Hz clock rate, and want to read with ReadMultiSample 10 Samples.
I used: Stream.ReadOverwriteMode = ReadOverwriteMode.OverwriteUnreadSamples; in the constructor, to be sure, that if my loop is too frequently, not the old 200 values which are stored in one second are used.
Is this right?
How can I get real Time values?
Please reply!
Thanks a lot!
Yours, Klaus
(3,457 Views)
I want also explain, that i  use my function in a loop witch needs at least 64msec of time.
maybe i am reading the old values from the buffer? but with continous samples, there is no buffer, am I right?
Please help!
(3,454 Views)
See my response here about the old data. Yes, there is an internal buffer with a cont. acquisition operation.
Bilal Durrani
NI
(3,447 Views)
