ReadSingleSample() does not work when ni box is connected via lan to usb
Hey there!
I have my NI Box connected to my PC via a LAN to USB box from silex.
Now I am trying to read out the analog channels with the method ReadSingleSample from the AnalogMultiChannelReader class.
This call never returns I call the method inside of a task which has an endless timeout.
Is this a known issue? Is there any workarround?
I use the C# API
Thank you very much
Phil
(5,661 Views)
NI box?
What is that?
(5,652 Views)
Hi Phil,
I would have the same question: What kind of NI hardware are you using?
It is always helpful if you provide us with a bigger portion of the source code or even the project as a attachment.
Christoph
Staff Applications Engineer
Certified LabVIEW Developer (CLD), Certified LabVIEW Embedded Systems Developer (CLED)
Don't forget Kudos for Good Answers, and Mark a solution if your problem is solved
(5,634 Views)
Hey
Here is my configuration:
I use the NI Box USB6009 OEM which is connected with a Lan to USB box from silex (SX-3000GB) to the PC.
My Code is very simple no big deal I thought
AnalogMultiChannelReader reader = new AnalogMultiChannelReader(analogRead.Stream);
analogRead.Control(TaskAction.Verify);
double[] data = reader.ReadSingleSample(); // TODO: This read is not working via lanToUSB
 analogRead is an instance of the class NationalInstruments.DAQmx.Task
And the application does not return from the last call reader.ReadSingleSample()
I hope that helps you to understand my problem
Phil
(5,623 Views)
@schlaug wrote:
Hey
Phil
Have you verified that this set-up works?
Are you able to makethe readings using NI-MAX?
Sounds like you may have a problem with your LAN to USB adapter.
(5,604 Views)
