Returning ViChar[] from VC++ to VB
I'm experimenting in VC.NET, as several may have noticed.
I have some strings in VC++ of type ViChar[255]. How can I return these to
VB in a form that VB sees as a string, which I assume is a pointer to a
System::String object created within my C code?
My present solution is highly inelegant, using memcpy to copy the bytes from
the address of the ViChar string to a char array that can then be returned.
VB then sees it as an SByte array and I have to loop through the array to
rebuild the original string.
I have been unable to declare a function parameter as ViChar[] since I get
into the circular loop;
error C2697: 'test' : must explicitly specify __gc or __nogc for an array
declared in a managed type
or
error
C3150: 'test' : '__gc' can only be applied to a class, struct,
interface, array or pointer
depending on whether I put the __gc there or not.
Dr. Craig Graham, Software Engineer
Advanced Analysis and Integration Limited, UK. http://www.aail.co.uk/
(4,743 Views)
You can convert a ViChar array to a .NET string via either a.) the .NET string constructor or b.) System.Runtime.InteropServices.Marshal.PtrToStringAnsi. For example, here is a managed C++ class that provides methods that demonstrate both of these methods:
#pragma once
#include "C:\VXIpnp\WinNT\include\visatype.h"
using namespace System;
using namespace System::Runtime::InteropServices;
namespace ViCharTest
public __gc class Test
public:
Test()
System::String* GetStringViaConstructor()
ViChar* value = "Test";
return new String(value);
System::String* GetStringViaMarshal()
return Marshal::PtrToStringAnsi(IntPtr(value));
You can then test these from a VB.NET client like this:
Dim test As ViCharTest.Test = New ViCharTest.Test
MsgBox(test.GetStringViaConstructor())
MsgBox(test.GetStringViaMarshal())
I believe that either of these approaches will do what you want. Please give this a try and reply to let us know how it worked out. Thanks.
- Elton
(4,743 Views)
"Elton Wells" wrote in message
news:5065000000050000001A120100-1042324653000@exchange.ni.com...
Ooo, very nice. Thanks.
(4,743 Views)
