SCardControl and FEATURE_VERIFY_PIN_DIRECT
Hi
I have a Reader that has a pinpad attached to it (OmniKey HID) and would like to validate the PIN once a card in the reader is detected.
I have been told that I could use methods of Winscard to achieve this.
FEATURE_VERIFY_PIN_DIRECT structure and
[DllImport("WINSCARD.DLL")]
 public static extern Int32 SCardControl(IntPtr hCard,uint dwControlCode,refbyte[] lpInBuffer,uint nInBufferSize,refbyte[] lpOutBuffer,uint nOutBufferSize,refuint lpBytesReturned);
are what is needed .
Since I m doing this in .net and C# has anyone got a working example of this  as I think my c# wrapper may be incorrect.
(8,226 Views)
Accepted by BADMULLAH
Hi Badmullah,
I think your best bet is to try talking to the HID support: http://www.hidglobal.com/main/technical-support/
If you search “WINSCARD.DLL” The first KB gives you a little information about communication with Omnikey readers.
I found the user Guide for PC Pinpad Smartcard Readers where the SCardControl method is described on page 6 - http://support.gemalto.com/fileadmin/user_upload/user_guide/Pinpad/PCPinpad_PC-SC_UserGuide.pdf
I might be able to give you some suggestions with an error code or something along those lines, but I’m not familiar with the OmniKey HID and wouldn’t be able to try anything.
Michael Miracle
NI Americas | AE
(8,221 Views)
Thanks Micheal
with some juggling the code in
PC Pinpad Smartcard reader
PC/SC Application note.
Version : Version 3
Last update : 05/26/2007
page 18 made my job easier.
Thanks for responding.
Cheers
(8,217 Views)
Hi again ;
I had a go at the code and got a 6E 00 response which I m not sure if its related to the *** SCardControl : Load GemPC Pinpad strings ***: Error status (0x1) error or not
SCardControl sample code with examples of PCSC V2 part 10 commands
0: FT SCR2000 0
1: FT SCR2000 1
2: OMNIKEY CardMan 3821 0
 Protocol: 0 on reader: OMNIKEY CardMan 3821 0
SCardConnect: OK
==> Get GemPC Firmware
 Firmware: ..... (length 256 bytes)
SCardControl: Error status (0x1)
==> Get Feature Request
 TLV length = (18) sizeof(PCSC_TLV_STRUCTURE) = 6: 06 04 00 31 30 0C 07 04 00 31
 30 10 0A 04 00 31 30 08
FEATURE_VERIFY_PIN_DIRECT implemented in the reader
FEATURE_MODIFY_PIN_DIRECT implemented in the reader
SCardControl: OK
==> Load strings in the Pinpad memory
==> Get card status
 Reader: OMNIKEY CardMan 3821 0 (length 24 bytes)
 State: 0x5
 Prot: 0
 ATR (length 23 bytes): 3B FD 18 00 00 80 31 FE 45 73 66 74 65 2D 63 64 30 38 30
 2D 6E 66 DC
SCardStatus: OK
 Protocol: 2
SCardReconnect: OK
==> Secure verify PIN
 command: 1E 00 82 04 00 08 04 02 01 04 09 00 00 00 00 0D 00 00 00 A0 20 00 01 0
8 FF FF FF FF FF FF FF FF
Enter your PIN in the Pinpad reader keypad...
 card response: 6E 00
Any idea?
(8,215 Views)
Hi Badmullah,
Are you using Measurement Studio? What kinds of National Instruments Products are you using?
Michael Miracle
NI Americas | AE
(8,207 Views)
Using Micorsoft Visual C++ ver 6.0
(8,205 Views)
Hi Badmullah,
I found some general questions related to the OMNIKEY Readers (http://www.hidglobal.com/faqs.php?techCat=19).
There’s some example code under specific programming questions for interacting with the cards.
It sounds like they will answer questions via email (support@OMNIKEY.COM). I didn’t find anything too useful from searching their knowledgebases.
You might have more luck on a Visual C++ forum perhaps (http://social.msdn.microsoft.com/forums/en-US/category/visualc/)?
Hopefully this is helpful.
Michael Miracle
NI Americas | AE
(8,200 Views)
