Save Measurement Studio Waveform graph as a file to playback later
I'd like to see if there's an easier way to save the data that's been rendered on a waveform graph (configured as a strip chart) than capturing the incoming data in code and sending copies of it to a file. It would be nice if there was a method to do this, with all the relevant metadata saved in the file (color, etc). Even better, the file then could be opened in a labview application (such as a TDMS file.) for later review.
thanks.
ps. i'm using VS2010 and MS 2010.
(6,312 Views)
Where is the data for the waveform graph coming from?
Humphrey H.
(6,281 Views)
hi - the data is coming from a custom IO subsystem (built on CAN) that arrives in the PC as an interrupt generated by a HID class device. i unpack the HID packet and present it to the graph every time a new packet arrives. if recording is selected, i also build a byte array that copies the data into the byte array for a later save operation.
but as long as i have you, is there an easy way to return a strip chart to its starting position (ie time = t0)?
thanks,
Jim
(6,264 Views)
Accepted by topic author djcoburn
So it sounds like you have all the data points already. For the metadata you mentioned, line colors, plot colors, point colors, line styles, etc. are all accessible from properties so if you wanted to, you can retrieve all that data.
I believe that starting back at t0 is the same as clearing the history so you can use the ClearData() method.
Humphrey H.
(6,257 Views)
