Scatter plot: gradient color
I can't seem to find an example where I can create a custom plot class. I need to be able to color the line of the plot as a function of it's Y value, and make it look like a smooth gradient. Ideally I'd like to change the point size of the line as well. This would allow me to "plot" 3 variables using a 2D graph. I've started (VB.Net):
Imports NationalInstruments.UI
Public Class clCustomPlot
Inherits ScatterPlot
Public Sub New()
MyBase.New()
End Sub
 Protected Overrides Sub OnBeforeDraw(ByVal sender As Object, ByVal e As NationalInstruments.UI.BeforeDrawXYPlotEventArgs)
End Sub
End Class
But VS tells me that:
Error MeasStudioGraphLineColour sub 'OnBeforeDraw' cannot be declared 'Overrides' because it does not override a sub in a base class.
Thanks for your help,
Nicolas
(6,764 Views)
Hello Nicolas,
You will actually want to create your own custom LineStyle class.  There is an excellent example of how to do that in the Measurement Studio help topic entitled "Creating a Custom Line Style for the Measurement Studio Web Forms Graph .NET Controls" Also, you may want to check out a forum I recently answered using a similar method - found here.  Let me know if you have any questions.
NickB
(6,763 Views)
Ok, had a first go at it. Am getting an error which I've seen before when trying to do this but couldn't solve. Could be "VB" related? I attached my code and here is the error:
 System.ArgumentException was unhandled
  Message="Parameter is not valid."
  Source="System.Drawing"
  StackTrace:
       at System.Drawing.Pen.get_Color()
       at NationalInstruments.UI.Internal.a5.a(Graphics A_0, Rectangle A_1, di A_2)
       at NationalInstruments.UI.Internal.a7.a(ComponentDrawArgsInternal A_0)
       at NationalInstruments.Restricted.ControlElement.a(ComponentDrawArgsInternal A_0, Rectangle A_1, Boolean A_2)
       at NationalInstruments.Restricted.ControlElement.DrawChildren(ComponentDrawArgsInternal args, Rectangle clipRectangle)
       at NationalInstruments.Restricted.ControlElement.a(ComponentDrawArgsInternal A_0, Rectangle A_1)
       at NationalInstruments.Restricted.ControlElement.Paint(PaintEventArgs e)
       at NationalInstruments.UI.WindowsForms.ControlBase.OnPaint(PaintEventArgs e)
       at System.Windows.Forms.Control.PaintWithErrorHandling(PaintEventArgs e, Int16 layer, Boolean disposeEventArgs)
       at System.Windows.Forms.Control.WmPaint(Message& m)
       at System.Windows.Forms.Control.WndProc(Message& m)
       at System.Windows.Forms.Control.ControlNativeWindow.OnMessage(Message& m)
       at System.Windows.Forms.Control.ControlNativeWindow.WndProc(Message& m)
       at System.Windows.Forms.NativeWindow.DebuggableCallback(IntPtr hWnd, Int32 msg, IntPtr wparam, IntPtr lparam)
       at System.Windows.Forms.UnsafeNativeMethods.DispatchMessageW(MSG& msg)
       at System.Windows.Forms.Application.ComponentManager.System.Windows.Forms.UnsafeNativeMethods.IMsoComponentManager.FPushMessageLoop(Int32 dwComponentID, Int32 reason, Int32 pvLoopData)
       at System.Windows.Forms.Application.ThreadContext.RunMessageLoopInner(Int32 reason, ApplicationContext context)
       at System.Windows.Forms.Application.ThreadContext.RunMessageLoop(Int32 reason, ApplicationContext context)
       at System.Windows.Forms.Application.Run(Form mainForm)
       at MeasStudioGraphLineColour.frmMain.Main() in D:\Source\MiscVB.Net\MeasStudioGraphLineColour\frmMain.vb:line 1
       at System.AppDomain._nExecuteAssembly(Assembly assembly, String[] args)
       at System.AppDomain.ExecuteAssembly(String assemblyFile, Evidence assemblySecurity, String[] args)
       at Microsoft.VisualStudio.HostingProcess.HostProc.RunUsersAssembly()
       at System.Threading.ThreadHelper.ThreadStart_Context(Object state)
       at System.Threading.ExecutionContext.Run(ExecutionContext executionContext, ContextCallback callback, Object state)
       at System.Threading.ThreadHelper.ThreadStart()
  InnerException:
 Thanks for your help Nick!
(6,760 Views)
The forum wouldn't let me attach a zip with my code so here it is (gr is a ScatterGraph on the form which initially contains no plot):
   Private Sub frmMain_Load(ByVal sender As System.Object, ByVal e As System.EventArgs) Handles MyBase.Load
    Dim pl As New NationalInstruments.UI.ScatterPlot
    Me.gr.Plots.AddRange(New NationalInstruments.UI.ScatterPlot() {pl})
    pl.XAxis = Me.XAxis1
    pl.YAxis = Me.YAxis1
    Dim X(1000) As Double
    Dim Y(1000) As Double
    For i As Integer = 0 To 1000
      X(i) = CDbl(i)
      Y(i) = 5 + (5 * Math.Cos(i * Math.PI / 180)) * ((i + 1) / 1000)
    pl.LineStyle = New clGradientLineStyle
    pl.PlotXY(X, Y)
  End Sub
 Public Class clGradientLineStyle
  Inherits LineStyle
  Private _startColor As Color
  Private _endColor As Color
  Public Sub New()
    MyClass.New(Color.Red, Color.Blue)
  End Sub
  Public Sub New(ByVal startColor As Color, ByVal endColor As Color)
    _startColor = startColor
    _endColor = endColor
  End Sub
  Public Property StartColor() As Color
    Get
      Return _startColor
    End Get
    Set(ByVal value As Color)
      _startColor = value
    End Set
  End Property
  Public Property EndColor() As Color
    Get
      Return _endColor
    End Get
      _endColor = value
    End Set
  End Property
  Public Overrides ReadOnly Property IsContextDependent() As Boolean
    Get
      ' Return true to indicate that CreatePen
      ' should be called for any change in context
      Return True
    End Get
  End Property
  Public Overrides Function CreatePen(ByVal context As Object, ByVal args As LineStyleDrawArgs) As Pen
    Dim bounds As Rectangle = args.ContextBounds
    ' Add 1 to width and height of context bounds to include
    ' the right and bottom edge of the rectangle in the linear
    ' gradient brush
    bounds.Width += 1
    bounds.Height += 1
    Dim brush As Brush
    Try
      brush = New LinearGradientBrush(bounds, StartColor, EndColor, LinearGradientMode.Vertical)
      Return New Pen(brush, args.Width)
    Finally
      If Not (brush Is Nothing) Then
        brush.Dispose()
      End If
    End Try
  End Function
End Class
(6,758 Views)
 I've now tried implementing the example
 Creating a Custom Line Style for the Measurement Studio Windows Forms Graph .NET Controls
and get the same error. I'm using VS2008. Can you replicate this on your side?
(6,753 Views)
I've now tride implementing it in C#. I get the exact same error so I must be doing something wrong! Here's the code:
public partial class Form1 : Form
    public Form1()
      InitializeComponent();
    private void Form1_Load(object sender, EventArgs e)
      double[] x = new double[1000];
      double[] y = new double[1000];
      for (int i = 0; i < 1000; i++)
      x[i]=i;
      y[i] = 5 + (5 * Math.Cos(i * Math.PI / 180)) * ((i + 1) / 1000);
      GradientLineStyle GL;
      GL=new GradientLineStyle();
      scatterPlot1.LineStyle = GL;
      scatterPlot1.PlotXY(x, y);
  public class GradientLineStyle : NationalInstruments.UI.LineStyle
    private Color _startColor;
    private Color _endColor;
    public GradientLineStyle()
      : this(Color.Red, Color.Blue)
    public GradientLineStyle(Color startColor, Color endColor)
      _startColor = startColor;
      _endColor = endColor;
    public Color StartColor
      get
        return _startColor;
      set
        _startColor = value;
    public Color EndColor
      get
        return _endColor;
      set
        _endColor = value;
    public override bool IsContextDependent
      get
        // Return true to indicate that CreatePen
        // should be called for any change in context
        return true;
    public override Pen CreatePen(object context, NationalInstruments.UI.LineStyleDrawArgs args)
      Rectangle bounds = args.ContextBounds;
      // Add 1 to width and height of context bounds to include
      // the right and bottom edge of the rectangle in the linear
      // gradient brush
      bounds.Width += 1;
      bounds.Height += 1;
      using (Brush brush = new LinearGradientBrush(bounds, StartColor, EndColor, LinearGradientMode.Vertical))
        return new Pen(brush, args.Width);
(6,750 Views)
Accepted by topic author FFCyrille
I got it working! For all those interested, here is a VB.Net custom ScatterPlot which will show you how to control/color every step of the line.
Imports System.Drawing
Imports System.Drawing.Drawing2D
Public Class clCustomScatterPlot
  Private dblMin As Double
  Private dblMax As Double
  Private colMinColour As System.Drawing.Color
  Private colMaxColour As System.Drawing.Color
  Public Sub New(ByVal MinValue As Double, ByVal MaxValue As Double, _
                 ByVal MinValueColour As System.Drawing.Color, ByVal MaxValueColour As System.Drawing.Color)
    MyBase.New()
    ' no checking is done for the fact that MinValue<MaxValue
    dblMin = MinValue
    dblMax = MaxValue
    colMinColour = MinValueColour
    colMaxColour = MaxValueColour
  End Sub
  Protected Overrides Sub OnBeforeDraw(ByVal e As BeforeDrawXYPlotEventArgs)
    ' Clip data, iterate through clipped data, map, and draw.
    Dim plot As XYPlot = e.Plot
    Dim clippedXData() As Double = Nothing
    Dim clippedYData() As Double = Nothing
    plot.ClipDataPoints(clippedXData, clippedYData)
    For i As Integer = 0 To clippedXData.Length - 2
      Dim x1 As Double = clippedXData(i)
      Dim x2 As Double = clippedXData(i + 1)
      Dim y1 As Double = clippedYData(i)
      Dim y2 As Double = clippedYData(i + 1)
      Dim point1 As PointF = plot.MapDataPoint(e.Bounds, x1, y1)
      Dim point2 As PointF = plot.MapDataPoint(e.Bounds, x2, y2)
      Dim pen As Pen = New Pen(ValueToColour(y2))
      Dim g As Graphics = e.Graphics
      g.DrawLines(pen, New PointF() {point1, point2})
    e.Cancel = True
  End Sub
  Private Function ValueToColour(ByVal value As Double) As Color
    If value <= dblMin Then Return colMinColour
    If value >= dblMax Then Return colMaxColour
    Dim pctg As Double = (value - dblMin) / (dblMax - dblMin)
    Dim a, r, g, b As Integer
    a = CInt(CInt(colMinColour.A) + pctg * (CInt(colMaxColour.A) - CInt(colMinColour.A)))
    r = CInt(CInt(colMinColour.R) + pctg * (CInt(colMaxColour.R) - CInt(colMinColour.R)))
    g = CInt(CInt(colMinColour.G) + pctg * (CInt(colMaxColour.G) - CInt(colMinColour.G)))
    b = CInt(CInt(colMinColour.B) + pctg * (CInt(colMaxColour.B) - CInt(colMinColour.B)))
    r = Math.Max(0, r) : r = Math.Min(255, r)
    g = Math.Max(0, g) : g = Math.Min(255, g)
    b = Math.Max(0, b) : b = Math.Min(255, b)
    Return System.Drawing.Color.FromArgb(a, r, g, b)
    Dim col As Color = System.Drawing.Color.FromArgb(a, r, g, b)
    Return col
  End Function
End Class
(6,742 Views)
