ScatterGraph with multiple y values on same x axis
I am having trouble adding a data array to multiple Yaxis but sharing the same Xaxis. Currently Yaxis1 is set to the left scale and Yaxis2 is set to the right scale. I am using using
scattergraph1.PlotXY(Frequency, S21_dB)          'Left yaxis0
To add the first data array. I then follow with
sg1.PlotXY(Frequency, S11_dB)                         'Right yaxis1
sg1.PlotXY(Frequency, S22_dB)                         'Right yaxis2
To add the rest of the data. This isn't correct it defaults and writes over the first set of data.
Example code or project would be helpful!
Chao for now
SloMotion
(4,511 Views)
Hello SloMotion,
The following thread should point you in the direction:
how to plot mulitple graph in scattergraph control?
Let me know if this helps!
Best,
Peter Rifken - Field Engineer & Business Manager
Boston / North New England & Maine
(4,482 Views)
