Serialize scattergraph
It try to serialize a scattergraph, to save all the properties modified by the user.
I have some returned errors that say a lot of parts of properties are not serializable. I try with a visual studio textbox and it works fine.
Is there a solution to serialize a scattergraph ?
Regards
(5,483 Views)
Hi, virgule
In the future, please post exceptions that you are seeing so it is easier for other forum users to confirm whether they are seeing the same error as you. I tried doing the following in the constructor of my main form, and I think I reproduced the error you are reporting:
var stream = File.Open(XmlFilePath, FileMode.Truncate, FileAccess.ReadWrite, FileShare.ReadWrite);
var serializer = new XmlSerializer(typeof(ScatterGraph));
serializer.Serialize(stream, this._scatterGraph);
The exception that is thrown is as follows:
System.InvalidOperationException
HResult=-2146233079
Message=Cannot serialize member 'System.ComponentModel.Component.Site' of type 'System.ComponentModel.ISite',
see inner exception for more details. Source=System.Xml
The ScatterGraph class derives from System.ComponentModel.Component which contains this ISite member, which is not serializable.
I would recommend first identifying data on the scatter graph that is of interest to you. After you have aggregated the pieces of data you want, create a separate class which holds the data. When you want to serialize the scatter graph, create an instance of this data class and serialize that instead.
Daniel Dorroh
(5,414 Views)
Hi, D_Cubed
Sorry for the post exceptions and thank for your reply.
Can you give an example of aggregated pieces of data and how to create a separate class which holds the data ?
(An example of the scatterplot or axes class wich are implemented in the primary class scattergraph)
Regards
(5,383 Views)
Hi, virgule
You will need to choose what parts of the graph you are interested in serializing. I have attached a simple example that shows a serialization model class I created for use in serialization.
The serialization model looks like the following:
public class ScatterGraphSerializationModel
    public ScatterGraphSerializationModel()
        : this(new ScatterGraph())
    public ScatterGraphSerializationModel(ScatterGraph scatterGraph)
        // Store the scatter graph's identifier.
        Name = scatterGraph.Name;
        // Store the first scatter graph x-axis mode.
        XAxisMode = scatterGraph.XAxes[0].Mode;
        // Store more properties.
        // Store every plot's x- and y-data.
        foreach (var plot in scatterGraph.Plots)
            Plots.Add(new XYData { XValues = ((ScatterPlot)plot).GetXData(), YValues = ((ScatterPlot)plot).GetYData() });
    public string Name { get; set; }
    public AxisMode XAxisMode { get; set; }
    // Add more public properties to the serializable model.
    public List<XYData> Plots
        get
            if (_plots == null)
                _plots = new List<XYData>();
            return _plots;
        set { _plots = value; }
    public class XYData
        public double[] XValues { get; set; }
        public double[] YValues { get; set; }
    private List<XYData> _plots;
The example model stores the name of the graph, the mode for the x-axis, and the plot data on the graph. You will need to create your own model of data you wish to serialize.
Daniel Dorroh
(5,366 Views)
