Serializing NI Controls
Hi. Im creating an application using measurement studio 8.5 in MS VS2008 with C#.  This application requires the serialization of both NI forms and web controls.  From my tests it appears that neither type of control can be serialized in either binary or xml fromat.  Is this an oversight on the part of NI or simply a bug?  Any help in furthering my understanding would be appreciated. Thanks in advance.
(3,600 Views)
Hi EvaDav,
You should be able to serialize the NI (form) controls in Visual Studio 2008.
To check a control for the ability to apply serialization, please use code similar to this:
If Not Obj Is Nothing Then
If Obj.GetType().IsSerializable Then
However I am not sure you can serialize web controls. What web controls are you using?
Regards
JamesC
NIUK and Ireland
It only takes a second to rate an answer 🙂
(3,564 Views)
