Set increment of NumericEdit from measurement studio in C# winform
Hi All,
Can anyone suggest a way to set the increment/decrement value using NumericEdit when clicking the up/down arrows?
The default value is 1. What if I want to set it to 0.1?
Elliot
(3,047 Views)
You can use the CoercionInterval property to change the increment.
~ Paul H
(3,026 Views)
I tried "CoercionInterval" and set it to 0.1
this.NumericEdit.CoercionInterval = 0.1;
However, the increment/decrement is still 1 when I click it at UI.
(3,001 Views)
(2,990 Views)
Accepted by topic author Elliot_Elep
Strange that setting the property in code did not work for you . . . the only apparent difference was I set it from the property grid (though that just does the same setting in code in the .Design.cs file):
Are you setting CoercionInterval anywhere else, perhaps?
~ Paul H
(2,981 Views)
Find the root cause.
My numeric edit is "sourced" to a slide. BOTH slide and numeric edit should set the CoercionInterval to 0.1.
Thanks for your help!
(2,966 Views)
