Setting color to a individual point of a plot in scatter graph
In a ScatterGraph, i want to differentiate each point with different colors based on the value of the point. is it possible?, how can we do that.
Sakthi.
(4,373 Views)
Hey Sakthi,
Look at the example located here: C:\Program Files\National Instruments\MeasurementStudioVS2003\DotNET\Examples\UI\Graph\CustomStyles
You can look at the VB one or the CS one.  I think that is what you want.
jigg
CTA, CLA
testeract.com
~Will work for kudos and/or BBQ~
(4,358 Views)
Thanks for the reply SAM.
I need to change the color of the individual point based on a value which will be taken from an external array. but not based on the x and y values of the PointStyleDrawArgs.
any idea?.
(4,350 Views)
Do you mean that you want to change all the points that are over 100 (for instance) to be a certain color?
jigg
CTA, CLA
testeract.com
(4,336 Views)
No Sam, for example, i'm having an array contains the values 12, 25, 167, 08, 53, 23, 86. Now the point which is having the value 08 should be colored light, the point having the value 167 should be colored dark, the other points are to be colored in a range of light to dark based on the value of the point.
(4,329 Views)
Something like this!!
jigg
CTA, CLA
testeract.com
(4,318 Views)
Thanks Sam,
This really helped me to get an idea and solution. Thanks again!.
(4,304 Views)
