Setting the XPosition of a XyCursor
in the attached example I try to set the XPosition of an XYCursor. The SnapMode is ToPlot. When I set the XPosition on an valid x-value, the cursor is automatically set to an other x-value in the near of the point. When I zoom in the graph and there are not so many points on the screen, it works fine.
Best regards
Gerald
(4,739 Views)
Hi, Gerald
I believe the behavior you are reporting is a bug, and I have filed bug ID 537212 to address it. I've also been able to work around the issue as follows:
private void numericUpDown1_ValueChanged(object sender, EventArgs e)
    var xValue = ( double )numericUpDown1.Value;
    var xData = this.scatterPlot1.GetXData(  );
    int xIndex = Array.FindIndex( xData, val => val == xValue );
    // A value of -1 indicates the xValue was not found in xData.
// You may want to handle a value of -1 by finding a close match to xValue. if ( xIndex != -1 ) this.xyCursor1.MoveCursor( xIndex ); }
Please let me know if you have any questions or if this work around doesn't fit your requirements.
Daniel Dorroh
(4,685 Views)
thank you for the fast answer. The workaround is perfect for me.
Best regards
Gerald
(4,673 Views)
