Should I get Measurement Studio to use old C drivers with C# .NET?
I am making a very simple test automation system for a very old test set using MS Visual Studio and C#. I do not have a large budget so I do not want to purchase NI Measurement Studio if I don't need it. I have seen that there is some kind of wizard that lets me make a "wrapper class" in C# out of old C drivers for old instruments. My instruments are very old and do not have native C# drivers. Does it make sense to pay for NI Measurement Studio only for this function? Is there a simple way to do this without using NI Measurement Studio? I will not be using any charts, knobs, or other special controls. The GUI elements that come with MS Visual Studio are good enough for me. I will not be using any special data processing functions, the standard C# functions are enough for me.
(5,433 Views)
Hi Joshxdr,
You are right about the wrapper classes in measurement studio, what we are doing is calling a C DLL with C# code.  You can create this setup manually yourself, it is just made a lot more convenient using Measurement Studio. Furthermore, you can download the Measurement Studio evaluation to see whether or not this is worth the convenience to you.
Basil
Applications Engineering
(5,420 Views)
Thanks for your reply. It turns out that on my desktop PC I have a site license that I can use to try out NI MS. It was tricky to get the C# DLL wrapper wizard to work, since I need the CVI interface file (.fp) to make the wizard work. Luckily I was able to find these after a lot of hunting. There does not seem to be a standard place for these to go when you install a non-NI driver. The NI MS has a lot of nice features, and the price is pretty cheap compared to something like LabVIEW, so I will probably go ahead and buy it.
(5,418 Views)
