Show round/whole numbers on x-axis when zoomed in
I want to show nice round numbers on the x-axis when the user zooms in.  It seems like I have to choose between CreateIntervalMode and CreateCountMode but I don't think they get me what I want.  What I really want is CreateIntervalMode with an offset because if the user zooms in to a range of 0.24 to 2.26 I would like the interval to be 0.2 but I want the first tick mark to be 0.4 not 0.24.
If I use interval mode then I would get numbers like 0.24, 0.44, 0.64, etc.
If I use count mode then I would get numbers like 0.24, 0.42, 0.60, etc (depending on how many counts I specify).
Neither of those are what I want.
Is there a way to accomplish this?
Dan
(5,641 Views)
There is no pre-defined mode with the behavior you want, but you can always define your own. Here is an example using a very simplisitic method to generate divisions along a custom interval:
    public sealed class CustomDivisionsMode : RangeDivisionsMode {
        public double? Interval { get; set; }
        public override IList<TData> GetDivisions<TData>( IRangeDataMapper<TData> mapper, int divisionsEstimate ) {
            var doubleMapper = (IRangeDataMapper<double>)mapper;
            var range = doubleMapper.Range;
            double interval = Interval ?? 1.0;
            double start = Math.Floor( range.Minimum / interval ) * interval;
            var divisions = Enumerable.Range( 0, int.MaxValue )
                .Select( i => start + interval * i )
                .TakeWhile( d => d <= range.Maximum )
                .Cast<TData>( )
                .ToList( );
            return divisions;
        public override IList<TData> GetSubdivisions<TData>( IRangeDataMapper<TData> mapper, IList<TData> dependentDivisions ) {
            return Auto.GetSubdivisions<TData>( mapper, dependentDivisions );
In XAML you would declare it on your axis as:
    <ni:AxisDouble Orientation="Horizontal" Range="0.24, 2.26">
        <ni:AxisDouble.MajorDivisions>
            <ni:RangeLabeledDivisions>
                <ni:RangeLabeledDivisions.Mode>
                    <local:CustomDivisionsMode Interval="0.2" />
                </ni:RangeLabeledDivisions.Mode>
            </ni:RangeLabeledDivisions>
        </ni:AxisDouble.MajorDivisions>
    </ni:AxisDouble>
(Note that the scale always includes the minimum and maximum labels; to hide them, you could look into a custom label presenter.)
~ Paul H
(5,637 Views)
Thank you.  This lead me to the solution I wanted.
(5,616 Views)
