Simulated Signals
I'm trying to find a way to continually acquire signals by generating them in software.
I'm using VS2012 and MS2015 and VB.net.
The issue that I'm having is that after about 8-12 generations the application shuts down.
Attached are the generatesignals, getSpectra Methods and the dataready event handler.
I think the issue is related to recursive calling the generate signals method causing Stack overflows but an exception is not thrown the app just shuts down.
Therefore are there any ideas regarding how I should keep call the generatesignals method until a stop button is pressed.
I have tried Timers, async methods etc. to no avail.
Regards
Steve
(6,860 Views)
Hi Steve,
Can you reattach the files, I don't think anything was uploaded with original post.
Cheers
Pete
Certified LabVIEW Architect
(6,816 Views)
Hi Pete,
Sorry.
Hopefully Code attached.
(6,801 Views)
Hi stevieB,
It seems we are missing some information here.
Please provide:
  • Detailed exception information. If you are getting a stack overflow or some other exception, use the Copy Exception Detail to clipboard option in the exception helper that appears, and post it here.
  • A description of the debugging you have performed so far to figure out the cause of the application closure.
  • More context for the posted code. The code you posted seems to depend on classes such as NMathClass which are not provided in your snippet. If you are starting from an example application, please let us know which one.
Daniel Dorroh
(6,794 Views)
I have the test application working now. (see attached)
The original issue was that the application just shut down after 10 updates.
There was no error message which is why I assumed it was some form of stack exception
Since then I have moved the getSectraData method to it's own class.
The questions that I have now are: -
  1.
What is the best/preferred method of waiting for the dataready event from the signal generation class
At the moment I'm using a timer to get the testSignals and a dataready event to obtain the generated time signals
Is it better to use a while loop within the getSignalsmethod and check for a is taskrunning variable?  Will it keep alive
Secondly is it better to raise a data event that passess both a framecount and the actual generated signals to the calling method
or is it better to pass the dataready event and get the data via a property in the class.
Finally on the Lofarplot it always starts as 12:00:00.  How can you make it start at the current time?
Cheers
Steve
(6,771 Views)
Hi StevieB,
Sorry I haven't replied in a long while I've had to shift my attention onto email and phone support.
If you are still having issues and you have SSP I would recommend emailing or phoning in to get another AE to look at the issue.
Kind regards
Pete
(6,557 Views)
