Stereo WAV file high pass filter
    Hello Folks,
Just a quick question. I wish to pass a high pass filter, 2.2KHz (20 pole Butterworth),  through a stero wav file.
The wav file has 16 bits per sample. Can I pass the data directly to the Butterworth function or do I have to break the data into two seperate channels and call the butterworth function twice.
Regards
Ciaran.
(3,339 Views)
Hi Ciaran,
Thanks for the question - the ButterworthHighpassFilter takes a 1D array of doubles as data to filter, so if your stereo channels are each part of a 2D array you will need to separate them out as you suggest to be able to pass them through the Butterworth filter separately.
I hope this helps!
Mark
NIUK & Ireland
(3,299 Views)
