Stop 9264 output signals
I have a cDAQ-9174 chassis with 9264, 9401 and 9485 modules. The 9264 module generates analog signals that I want to stop (set to 0s) immediately when one of the 9401 digital inputs changes. Is there a way to this internally without going through a PC?
I’ve tried to use a digital input as a PauseTrigger on analog output task. It stops the task but leaves analog outputs in a random state (last samples). The 9264 module does not support AOIdleOutputBehavior.ZeroVolts property.
I’ve also tried to route analog output signals through 9485 module and use a digital input as a StartTrigger / PauseTrigger on digital output task but the 9485 does not support DOLineStatesStartState / DOLineStatesDoneState / DOLineStatesPausedState properties.
eg
(5,224 Views)
Hello Eg,
Have you considered using a reference digital trigger. The reference trigger stops the acquisition and flushes all samples in the onboard DAQ FIFO to computer memory. Here is more information o different triggering options:
http://www.ni.com/white-paper/4329/en/
Jose R
(5,174 Views)
Hi Jose,
I’m getting the following error when I’m trying to create a reference trigger:
Specified property is not supported by the device or is not applicable to the task.
Property: NationalInstruments.DAQmx.ReferenceTrigger.Type
Task Name: Analog Output
Status Code: -200452
The reference trigger does not seem to be available for analog outputs.
Ed
(5,168 Views)
Hello Eg,
It seems the NI-8264 does not support the reference trigger property. Also it is not possible to accomplish this without going through the PC as you originally asked. What I would recommend is to generate a dummy finite signal of 0 V when you stop generating the original signal so make sure the last value is not the last samples values.
Jose R
(5,133 Views)
