Stop a vi hosted in a .Net assembly from a .Net C# application
I used Labview to build a .Net assemlby that contains a VI. I can start the VI operation from my C# .Net application but I can't stop it.
For example, I start broadcasting a signal from a data file. The data file is 20min long. What should I do to stop the broadcasting manually before the VI operation has ended?
(3,232 Views)
I am a little confused on what you are trying to do. What part of this has been built in LabVIEW? Also what is Measurement Studio doing for this application?
Best Regards,
Adam G
(3,214 Views)
I posted my qeury in the wrong forum. Plesae refer to
http://forums.ni.com/t5/LabVIEW/Stop-a-vi-hosted-in-a-Net-assembly-from-a-Net-C-application/m-p/1330...
Thank you in advance!
(3,208 Views)
