System.ArgumentException occurred when disposing IntrumentControlStrip objects
Hi Guys,
Though this is not a major issues, this had annoyed me for a while. I had an error with the designer when closing some forms. See image attached.
Then, while debugging, I saw some strange System.ArgumentException in the ouput.
Here's the error:
  Message="Impossible to convert objet type 'System.EventHandler' to type 'System.ComponentModel.CollectionChangeEventHandler'."
  Source="mscorlib"
  StackTrace:
       à System.RuntimeType.CheckValue(Object value, Binder binder, CultureInfo culture, BindingFlags invokeAttr)
And here's the call stack:
  mscorlib.dll!System.RuntimeType.CheckValue(object value, System.Reflection.Binder binder, System.Globalization.CultureInfo culture, System.Reflection.BindingFlags invokeAttr) + 0x313 bytes
  mscorlib.dll!System.Reflection.MethodBase.CheckArguments(object[] parameters = {Dimensions:[1]}, System.Reflection.Binder binder = null, System.Reflection.BindingFlags invokeAttr = Default, System.Globalization.CultureInfo culture = null, System.Signature sig = {System.Signature}) + 0xc8 bytes
  System.dll!System.ComponentModel.ReflectEventDescriptor.RemoveEventHandler(object component = {Plots=8}, System.Delegate value = {System.EventHandler}) + 0x155 bytes
  System.dll!System.ComponentModel.ReflectPropertyDescriptor.RemoveValueChanged(object component, System.EventHandler handler) + 0xbc bytes
  NationalInstruments.UI.dll!NationalInstruments.Restricted.PropertyChangePropertyDescriptor.RemoveValueChanged(object component = {Plots=8}, System.EventHandler handler = {System.EventHandler}) + 0x38 bytes
  NationalInstruments.UI.dll!NationalInstruments.UI.PropertyEditorSource.Dispose(bool disposing = true) + 0x80 bytes
  NationalInstruments.UI.dll!NationalInstruments.UI.PropertyEditorSource.Dispose() + 0x1d bytes
  NationalInstruments.UI.WindowsForms.dll!NationalInstruments.UI.WindowsForms.PropertyEditor.Dispose(bool disposing = true) + 0x89 bytes
  System.dll!System.ComponentModel.Component.Dispose() + 0xf bytes
  System.Windows.Forms.dll!System.Windows.Forms.ToolStripControlHost.Dispose(bool disposing) + 0x39 bytes
  NationalInstruments.UI.WindowsForms.dll!NationalInstruments.UI.WindowsForms.ToolStripPropertyEditor.Dispose(bool disposing = true) + 0xf7 bytes
  System.Windows.Forms.dll!System.Windows.Forms.ToolStrip.Dispose(bool disposing = true) + 0x1a8 bytes
  NationalInstruments.UI.WindowsForms.dll!NationalInstruments.UI.WindowsForms.InstrumentControlStrip.Dispose(bool disposing = true) + 0x85 bytes
  System.Windows.Forms.dll!System.Windows.Forms.Control.Dispose(bool disposing = true) + 0x170 bytes
> GraphLibrary.dll!Opsens.Controls.LabViewChart.Dispose(bool disposing = true) Line 21 C#
I think the line is the root of all this:
The InstrumentControlStrip again, but this time at run time also.
Can you guys look into this?  I had done some basics checks on my own code to see if I was wrong using it at some point, but I found nothing apparently wrong. This was also in 8.2.1 and it is still in 8.5.
Jean Gauthier
Opsens
(5,710 Views)
After some investigation it turns out that this set of lines were producing the ArgumentException:
NationalInstruments
.UI.WindowsForms.ToolStripPropertyEditor toolStripCursors;
this.toolStripCursors.Source = new NationalInstruments.UI.PropertyEditorSource(this.ChartGraph, "Cursors");
NationalInstruments
this
.toolStripAnnotations.Source = new NationalInstruments.UI.PropertyEditorSource(this.ChartGraph, "Annotations");
ChartGraph is a WaveformGraph.
I discovered that when I had changed the InstrumentControlStrip for a simple System.Windows.Forms.ToolStrip and still noticing the exception. So I narrow down the suspect to the ToolStripPropertyEditor object.
Tks for your support,
Jean Gauthier
Opsens
(5,708 Views)
To show you that the InstrumentControlStrip is now out of the loop, here's the new error:
(5,707 Views)
Hi Jean,
I am a little confused as to the state you are in. Are you seeing this problem with or without Measurement Studio controls? If you are seeing this behavior with Measurement Studio controls, then we can look into the issue but we just need some small example that demonstrates the behavior.  If you are seeing buggy behavior with non-NI controls, then you should probably talk to Microsoft about that behavior.
Either way, just clarify where you are at now.
Best Regards,
Jonathan N.
(5,700 Views)
Jonathan,
Sorry about that. I'll try to be clearer.
The error come from NI component ToolStripPropertyEditor when inserted into either a ToolStrip or InstrumentControlStrip object. The confusion come from the fact that I first tought that the error was coming from the InstrumentControlStrip object.
a line like this DOESN'T produce errors:
this
.toolStripInteraction.Source = new NationalInstruments.UI.PropertyEditorSource(this.ChartGraph, "InteractionModeDefault");
but a line like this DOES:
this
The fact that a PropertyEditorSource is linked to a a collection of cursors (or annotations also) seems to produce the errors.
Thk,
Jean
(5,680 Views)
