System.IO.FileLoadException after switching to NI 2019
I recently switched to NI 2019 and didn't realize that once my apps are deployed on a "production" system, they crash with "System.IO.FileLoadException".  I searched this forum and looks like it could be a mismatch with .NET version or something related.
  • Before I switched from 2015 to 2019 they worked fine on production systems.
  • Apps work fine on my computer and on the build machine (both have Measurement Studio 2019 installed)
  • I install the following as I always did, only this time it's 2019 instead of 2015:
    • NI.Common.dll
    • NI.Controls.dll
    • NI.Controls.Graphs.dll
  • Building targeting .NET 4.7.2
I attached all files I could gather for troubleshooting.  Please let me know what I am missing.  Thank you!
Edit:  this is what's inside .wer file
Version=1
EventType=CLR20r3
EventTime=132083006954137528
ReportType=2
Consent=1
ReportIdentifier=c3fbdc38-acbe-11e9-9bf5-54ee7530faae
IntegratorReportIdentifier=c3fbdc37-acbe-11e9-9bf5-54ee7530faae
Response.type=4
Sig[0].Name=Problem Signature 01
Sig[0].Value=ExpressCompTool.exe
Sig[1].Name=Problem Signature 02
Sig[1].Value=1.0.0.20
Sig[2].Name=Problem Signature 03
Sig[2].Value=ab5836b7
Sig[3].Name=Problem Signature 04
Sig[3].Value=ExpressCompTool
Sig[4].Name=Problem Signature 05
Sig[4].Value=1.0.0.20
Sig[5].Name=Problem Signature 06
Sig[5].Value=ab5836b7
Sig[6].Name=Problem Signature 07
Sig[6].Value=1
Sig[7].Name=Problem Signature 08
Sig[7].Value=3f
Sig[8].Name=Problem Signature 09
Sig[8].Value=System.IO.FileLoadException
DynamicSig[1].Name=OS Version
DynamicSig[1].Value=6.1.7601.2.1.0.256.48
DynamicSig[2].Name=Locale ID
DynamicSig[2].Value=1033
DynamicSig[22].Name=Additional Information 1
DynamicSig[22].Value=52a4
DynamicSig[23].Name=Additional Information 2
DynamicSig[23].Value=52a47bae162b5056874cd9b250824114
DynamicSig[24].Name=Additional Information 3
DynamicSig[24].Value=19d8
DynamicSig[25].Name=Additional Information 4
DynamicSig[25].Value=19d899072b5974d4d62c96d0f9ec7235
UI[2]=C:\Diagnostics\ExpressCompTool.exe
UI[3]=HF Comprehensive Tool has stopped working
UI[4]=Windows can check online for a solution to the problem.
UI[5]=Check online for a solution and close the program
UI[6]=Check online for a solution later and close the program
UI[7]=Close the program
LoadedModule[0]=C:\Diagnostics\ExpressCompTool.exe
LoadedModule[1]=C:\Windows\SYSTEM32\ntdll.dll
LoadedModule[2]=C:\Windows\SYSTEM32\MSCOREE.DLL
LoadedModule[3]=C:\Windows\system32\KERNEL32.dll
LoadedModule[4]=C:\Windows\system32\KERNELBASE.dll
LoadedModule[5]=C:\Windows\system32\ADVAPI32.dll
LoadedModule[6]=C:\Windows\system32\msvcrt.dll
LoadedModule[7]=C:\Windows\SYSTEM32\sechost.dll
LoadedModule[8]=C:\Windows\system32\RPCRT4.dll
LoadedModule[9]=C:\Windows\Microsoft.NET\Framework64\v4.0.30319\mscoreei.dll
LoadedModule[10]=C:\Windows\system32\SHLWAPI.dll
LoadedModule[11]=C:\Windows\system32\GDI32.dll
LoadedModule[12]=C:\Windows\system32\USER32.dll
LoadedModule[13]=C:\Windows\system32\LPK.dll
LoadedModule[14]=C:\Windows\system32\USP10.dll
LoadedModule[15]=C:\Windows\system32\IMM32.DLL
LoadedModule[16]=C:\Windows\system32\MSCTF.dll
LoadedModule[17]=C:\Windows\system32\nvinitx.dll
LoadedModule[18]=C:\PROGRA~2\Sophos\SOPHOS~1\SOPHOS~2.DLL
LoadedModule[19]=C:\Windows\system32\PSAPI.DLL
LoadedModule[20]=C:\Windows\system32\VERSION.dll
LoadedModule[21]=C:\Windows\Microsoft.NET\Framework64\v4.0.30319\clr.dll
LoadedModule[22]=C:\Windows\system32\MSVCR120_CLR0400.dll
LoadedModule[23]=C:\Windows\assembly\NativeImages_v4.0.30319_64\mscorlib\b308b9c61f65cf2dfd876031ee385ba4\mscorlib.ni.dll
LoadedModule[24]=C:\Windows\system32\ole32.dll
LoadedModule[25]=C:\Windows\system32\CRYPTBASE.dll
LoadedModule[26]=C:\Windows\system32\uxtheme.dll
LoadedModule[27]=C:\Windows\assembly\NativeImages_v4.0.30319_64\System\095a3392942c3d4eb888e6a32036acd8\System.ni.dll
LoadedModule[28]=C:\Windows\assembly\NativeImages_v4.0.30319_64\System.Core\75913bbaf1bee617a94dcd6b5df12a5d\System.Core.ni.dll
LoadedModule[29]=C:\Windows\assembly\NativeImages_v4.0.30319_64\WindowsBase\6110ecf056356557d5798a1583a1c434\WindowsBase.ni.dll
LoadedModule[30]=C:\Windows\system32\CRYPTSP.dll
LoadedModule[31]=C:\Windows\system32\rsaenh.dll
LoadedModule[32]=C:\Windows\assembly\NativeImages_v4.0.30319_64\PresentationCore\ceff7eae18ed09ff1116ebf9af497790\PresentationCore.ni.dll
LoadedModule[33]=C:\Windows\assembly\NativeImages_v4.0.30319_64\Presentatio5ae0f00f#\3d01d2b7bde19d91d70c4ff96eea3432\PresentationFramework.ni.dll
LoadedModule[34]=C:\Windows\assembly\NativeImages_v4.0.30319_64\System.Xaml\76a6a6b0f7fb1fbd64a800b5fc3d47bb\System.Xaml.ni.dll
LoadedModule[35]=C:\Windows\system32\dwrite.dll
LoadedModule[36]=C:\Windows\Microsoft.NET\Framework64\v4.0.30319\WPF\wpfgfx_v0400.dll
LoadedModule[37]=C:\Windows\system32\MSVCP120_CLR0400.dll
LoadedModule[38]=C:\Windows\system32\OLEAUT32.dll
LoadedModule[39]=C:\Windows\Microsoft.NET\Framework64\v4.0.30319\WPF\PresentationNative_v0400.dll
LoadedModule[40]=C:\Windows\system32\api-ms-win-core-xstate-l2-1-0.dll
LoadedModule[41]=C:\Windows\Microsoft.NET\Framework64\v4.0.30319\clrjit.dll
LoadedModule[42]=C:\Windows\Microsoft.NET\Framework64\v4.0.30319\nlssorting.dll
LoadedModule[43]=C:\Windows\system32\WRusr.dll
LoadedModule[44]=C:\Windows\system32\SHELL32.dll
LoadedModule[45]=C:\Windows\system32\MSIMG32.dll
LoadedModule[46]=C:\Windows\system32\profapi.dll
LoadedModule[47]=C:\Windows\system32\WindowsCodecs.dll
LoadedModule[48]=C:\Windows\assembly\NativeImages_v4.0.30319_64\System.Configuration\36778d2072c745f0ad72f7e219122258\System.Configuration.ni.dll
LoadedModule[49]=C:\Windows\assembly\NativeImages_v4.0.30319_64\System.Xml\8821b72d5d51079acf96e90c4af19a96\System.Xml.ni.dll
LoadedModule[50]=C:\Windows\system32\bcrypt.dll
LoadedModule[51]=C:\Windows\system32\RpcRtRemote.dll
LoadedModule[52]=C:\Windows\assembly\NativeImages_v4.0.30319_64\Presentatio1c9175f8#\7600f870ebcc661f412ab16465a64647\PresentationFramework.Aero.ni.dll
LoadedModule[53]=C:\Windows\system32\dwmapi.dll
LoadedModule[54]=C:\Windows\Microsoft.NET\Framework64\v4.0.30319\diasymreader.dll
FriendlyEventName=Stopped working
ConsentKey=CLR20r3
AppName=HF Comprehensive Tool
AppPath=C:\Diagnostics\ExpressCompTool.exe
(6,425 Views)
Looking at the NI .NET Deployment help topic, you may be missing the specific versions of the SharpDX assemblies that are referenced by the NationalInstruments.Controls.Graphs assembly.
Assuming it is an assembly load failure, you could also try using the .NET Assembly Binding Log Viewer to get more information about the specific failure.
~ Paul H
(6,411 Views)
Thank you, Paul.
Learned today how useful fuslogvw is (only used to depends.exe)
Anyway, I traced it down to this issue but I have no clue what it could be... didn't even know Version=17.5.40.49153 exists (didn't we go from 15 to 19?)
*** Assembly Binder Log Entry (07/23/2019 @ 03:15:33 PM) ***
The operation failed.
Bind result: hr = 0x80131040. No description available.
Assembly manager loaded from: C:\Windows\Microsoft.NET\Framework64\v4.0.30319\clr.dll
Running under executable C:\Diagnostics\ExpressCompTool.exe
--- A detailed error log follows.
=== Pre-bind state information ===
LOG: DisplayName = NationalInstruments.Common, Version=17.5.40.49153, Culture=neutral, PublicKeyToken=dc6ad606294fc298
(Fully-specified)
LOG: Appbase = file:///C:/Diagnostics/
LOG: Initial PrivatePath = NULL
LOG: Dynamic Base = NULL
LOG: Cache Base = NULL
LOG: AppName = ExpressCompTool.exe
Calling assembly : NationalInstruments.Controls, Version=19.0.45.54571, Culture=neutral, PublicKeyToken=4febd62461bf11a4.
LOG: This bind starts in default load context.
LOG: No application configuration file found.
LOG: Using host configuration file:
LOG: Using machine configuration file from C:\Windows\Microsoft.NET\Framework64\v4.0.30319\config\machine.config.
LOG: Post-policy reference: NationalInstruments.Common, Version=17.5.40.49153, Culture=neutral, PublicKeyToken=dc6ad606294fc298
LOG: GAC Lookup was unsuccessful.
LOG: Attempting download of new URL file:///C:/Diagnostics/NationalInstruments.Common.DLL.
LOG: Assembly download was successful. Attempting setup of file: C:\Diagnostics\NationalInstruments.Common.dll
LOG: Entering run-from-source setup phase.
LOG: Assembly Name is: NationalInstruments.Common, Version=19.0.40.49152, Culture=neutral, PublicKeyToken=dc6ad606294fc298
WRN: Comparing the assembly name resulted in the mismatch: Major Version
ERR: The assembly reference did not match the assembly definition found.
ERR: Run-from-source setup phase failed with hr = 0x80131040.
ERR: Failed to complete setup of assembly (hr = 0x80131040). Probing terminated.
(Fully-specified)
*** Assembly Binder Log Entry (07/23/2019 @ 03:16:35 PM) ***
(Fully-specified)
(Fully-specified)
(6,399 Views)
Ah, so it is a versioning issue with the Common assembly. This is covered in the Publisher Policy Files section  of the deployment help topic. I believe you will want to include an app.config file for your application that looks something like this:
<?xml version="1.0" encoding="utf-8"?>
<configuration>
  <runtime>
    <assemblyBinding xmlns="urn:schemas-microsoft-com:asm.v1">
      <dependentAssembly>
        <assemblyIdentity name="NationalInstruments.Common" publicKeyToken="dc6ad606294fc298" culture="neutral" />
        <bindingRedirect oldVersion="0.0.0.0-19.0.45.54571" newVersion="19.0.45.54571" />
      </dependentAssembly>
    </assemblyBinding>
  </runtime>
</configuration>
The Common assembly is shipped with .NET drivers as well as Measurement Studio libraries, so it is updated more frequently.
~ Paul H
(6,394 Views)
The DLL file version that I reference and install at the target machine is 19.0.40.49152 so I had to do this instead, does it make sense?
<bindingRedirect oldVersion="0.0.0.0-19.0.45.54571" newVersion="19.0.40.49152"/>
However, even with this change I still get error at the same place.  But this time it's only 2 instances of "Assembly Binder Entries" instead of 4.  So it definitely helped but only partly.  I do reference NationalInstruments.Common in other other supporting DLLs but there's no app.config for DLLs.  Does it mean I have to go through the process of creating global assembly cache?
Also, could you please clarify this quote "If you do not deploy an application configuration file and you deploy assemblies that were built with older versions of deployed assemblies (such as NationalInstruments.Common.dll), the deployed application may crash at assembly load time"
  1. Does it mean that app.config has to actually be deployed on the target machine (as in part of the installer)?
  2. Is there something I can do to avoid all of these redirects?  I mean, are they causes by the fact that at some point in time I used to have NI 2015?  Or can I install some .NET version that will patch this issue?
Thank you!
(6,387 Views)
Accepted by topic author kirko7
That seems fine to me (I just pulled the first version number from the error log you provided to create my example config file).
If all of those DLLs are loaded by the same application, then the app.config for that application should get used. Though if the DLLs are using conflicting versions of Common (or if the target machine does have some old version of Common already in the GAC), then updating the GAC may be required.
The app.config file just needs to be located next to the application (e.g. when you build your project, the app.config file should be automatically copied to the build folder as YourApplication.exe.config). Where you copy that file to the machine, or an installer puts it there, should not matter.
The Installer Builder tool was created to support these kinds of deployment scenarios. It can generate an installer that will perform any required GAC assembly registration automatically.
~ Paul H
(6,382 Views)
Phew!  I got this to work!  I did include the .config file but also turned out that I needed to update one of the Sharp*.dll files.
Thank you for guiding me through this!  I hope this will be useful for someone else.
(6,377 Views)
