System throwing null reference exception when creating voltage task
I am trying to read analog data on a 6009 DAQ using c#
However, when I try and create a voltage channel, I get a null reference exception. Can anyone point me in the right direction with this?
The exception happens on:
atask.AIChannels.CreateVoltageChannel(SquibCombo.Text,"", AITerminalConfiguration.Nrse,0,3.5,NationalInstruments.DAQmx.AIVoltageUnits.Volts);
SquibCombo.Text is "Dev2/ai0" at runtime
Thank you
David
(4,193 Views)
Hi David,
Please can you look at a C# example located at
C:\Documents and Settings\All Users\Documents\National Instruments\NI-DAQ\Examples\DotNET2.0\Analog In\Measure Voltage\ContAcqVoltageSamples_IntClk\cs
This will show you how to call the functions, and then allow you to modify the code for your purposes.
Regards
JamesC
NIUK and Ireland
It only takes a second to rate an answer 🙂
(4,181 Views)
In case anyone has the same problem, I wasn't initialising the task properly. Thanks for the reply
(4,163 Views)
