TDMS in Qt 5.4.0 (MSVC 2010, 32 bit)
I would like to integrate TDMS libraries to my Qt application( Qt 5.4.0 (MSVC 2010, 32 bit)).I would like to know whether Qt supports the  .net libraries .
-Sandeep
(4,979 Views)
Hi, Sandeep
Can you explain a bit more about what you're trying to do? Is the Qt application something you're writing in .NET?
Daniel Dorroh
(4,899 Views)
Yes, it's possible to call a .net library from a Qt application. Do let us know more on what you want to do.
(4,784 Views)
Thank you for your response....
I use HMI with ARM cortex processor with Linux ported.
I am developing HMI user interface application on Qt . I am able to make TDMS files in Qt using C library with Windows.
Now the problem is when I port Qt on my HMI which has Linux OS in it the C libraries will not work. I would need a .so file Cross compiled for ARM cortex in Linux.
(4,770 Views)
