Tank.Value not displayed correctly (NI MS .NET 8.0)
I'm developing an application in C# using Visual Studio 2005 that includes an instance of the Tank control.  Below are some key source code lines which initialize this control's properties:
this.m_tnkVolume.OutOfRangeMode = NationalInstruments.UI.NumericOutOfRangeMode.CoerceToRange;
this.m_tnkVolume.Range = new NationalInstruments.UI.Range (1E-10, 0.0001);
this.m_tnkVolume.ScaleType = NationalInstruments.UI.ScaleType.Logarithmic;
With the exception of some cosmetic properties (e.g. FillColor, CaptionFont, TankStyle, etc.), I have not changed any other characteristics of the control.
When I set the Value property in design mode to "0.000001" or "1E-6", the tank is filled correctly.  In fact, any number larger than "1E-6" is handled by the tank without incident.  However, if I set the Value property to "0.0000001" or "1E-7", the tank displays nothing (i.e. is empty).
I do not understand why the control is exhibiting this behavior; especially considering that "1E-7" is well within the specified range.  When I first observed the mis-behaving control, I suspected that a cast-ing bug was buried somewhere in my code; but the issue is clearly repeatable in design mode.
Does anyone know of specific properties I am over-looking?  Is this a known bug with this control in the library?  (Note:  I was only able to locate to Knowledge Base articles on the Tank control and neither relevant to my problem.)
Thank you for your help.
Matt
(3,993 Views)
Hey Matt,
It looks like this might be a bug with Measurement Studio; I'm not sure at this point.  I am reporting it to R&D, and will let you know if I find out anything.  I was able to reproduce it here, and it does not look like expected behavior.
Message Edited by AndrewMc on 11-17-2006 04:01 PM
Andy McRorie
NI R&D
(3,968 Views)
Thank you Andy for the prompt reply.  Please let me know when the R & D staff responds to you.
I am anxious to learn if there is a work-around or a comparable control I can use.
Is there another National Instruments URL where I should report this issue?
Thank you.
Matt
(3,940 Views)
Hey Matt,
I will let you know when I have an update for you regarding this.  Currently, R&D is looking into this, and I will let you know when I have more information.  There is no need to report this issue as I have reported the issue and it is being looked at.
Andy McRorie
NI R&D
(3,919 Views)
Andrew, thank you for responding to my post and acknowledging my suspicions concerning the Tank control.
As I waited for a response from your development team, I created a custom .NET "tank" control that is not troubled by small logarithmic values.  I will look into canceling/disabling/removing this thread.
Matt
(3,803 Views)
