Thousends of Empty Callbacks - Lower Frequenzy?
Hallo Everyone,
I am currently stuck at a strange problem: As soon as I start reading my Data from my USB-6210 I get tons of empty Callbacks with 0 Datasets to read. Here is my Code:
_frequenzy = 10000;
_clockTask = new Task();
_clockTask.COChannels.CreatePulseChannelFrequency("Dev2/freqout", "ClockPulses", COPulseFrequencyUnits.Hertz,
                COPulseIdleState.Low, 0, _frequenzy, 0.5);
_clockTask.Control(TaskAction.Verify);
_readAiChannelsTask = new Task();
_readAiChannelsTask.AIChannels.CreateVoltageChannel("Dev2/ai0", "Channel 1", AITerminalConfiguration.Differential, 0, 4,
                AIVoltageUnits.Volts);
_readAiChannelsTask.AIChannels.CreateVoltageChannel("Dev2/ai1", "Channel 2", AITerminalConfiguration.Differential, 0, 4,
_readAiChannelsTask.Timing.ConfigureSampleClock("/Dev2/PFI6", _frequenzy, SampleClockActiveEdge.Rising, SampleQuantityMode.ContinuousSamples,1000);
_readAiChannelsTask.Triggers.StartTrigger.ConfigureDigitalEdgeTrigger("/Dev2/PFI6", DigitalEdgeStartTriggerEdge.Rising);
_readAiChannelsTask.Control(TaskAction.Verify);
_readAiChannelsTask.Start();
_readAiChannelsTask1Reader = new AnalogMultiChannelReader(_readAiChannelsTask.Stream);
_readAiChannelsTaskCallback = new AsyncCallback(AnalogInCallback);
_readAiChannelsTask1Reader.SynchronizeCallbacks = true;
_readAiChannelsTask1Reader.BeginMemoryOptimizedReadMultiSample(1000, _readAiChannelsTaskCallback, _readAiChannelsTask, _data);
_clockTask.Start();
 As you see I read 2 AI Channels with an external Clock. Problem is: I get tons of tons off Callbacks with no Data included. My CallBack looks liek this:
_readAiChannelsTask1Reader.EndMemoryOptimizedReadMultiSample(ar, out _numberOfDataSets);
if (_numberOfDataSets == 0)
    int x = 0;
StreamWriter sw = new StreamWriter(@"C:\AllTheData.txt", true);
for (int i = 0; i < _numberOfDataSets; i++)
   sw.WriteLine("#" + _totalNumber.ToString(CultureInfo.InvariantCulture) + ": " +
                      _data[0, i].ToString("0.000", CultureInfo.InvariantCulture) + "," +
                      _data[1, i].ToString("0.000", CultureInfo.InvariantCulture));
   _totalNumber++;
sw.Close();
sw.Dispose();
_readAiChannelsTask1Reader.BeginMemoryOptimizedReadMultiSample(-1, _readAiChannelsTaskCallback,_readAiChannelsTask, _data);
 As you see I check for empty CallBacks which accure Non-Stop and create massiv amounts of CPU-Load. Non-Empty Callbacks occure with 1k batches of data, as I configured. How do I avoid these?
An additional Question is: the Prescaler for the "external" Clock only reaches to 16. So the lowest available frequenzy I can measure is 6250Hz. I want to go below this (~2kHz). Is there any nice way to achive this? An internal Clock is not an option as I need to synchronize an encoder Read with the AI channels.
Best
Kevin
(5,475 Views)
Hi Kevin,
have you tried to use a standard example shipped with Measurement Studio? I would recommand the example AIContAcquisition to you. It is localed on your computer at:
C:\Users\Public\Documents\National Instruments\NI-DAQ\Examples\DotNET4.0\Synchronization\Multi-Device\AIContAcquisition
If this does not help you, please upload the complete files so I can test them here myself and debug them.
Melanie
Melanie Eisfeld
Senior Applications Engineer, National Instruments Germany
Certified LabVIEW Developer
Certified TestStand Architect
(5,410 Views)
