Timer control labview code
I have a LabVIEW code which needs to be timer control. The code should work as follows?
1. Need a timer that resets every 60 seconds.
2. From 0-30 seconds, the code should write the value 0(zero) to Modbus register 9 of slave device address 5
3. from 31 - 60 seconds, the code will write the value 256 to same Modbus register 9 of slave device address 5.
4. The timer will reset to zero  and this loop continues for every 60 seconds.
Does anyone in the forum got an idea or a typical LabVIEW code that can perform the above function?
(3,787 Views)
This is the Measurement Studio forum, not LabVIEW, so I would recommend posting this in the appropriate forum.
NI does have a free unsupported Modbus API that you can use for your project:  https://forums.ni.com/t5/Reference-Design-Content/LabVIEW-Modbus-API/ta-p/3524019
I hope that helps.
Zofia
NI Technical Support Engineer
(3,758 Views)
Which of the Measurement Studio forum (VC++ or VB6) should I post my Question?
(3,748 Views)
Your question refers to "LabVIEW" code. So it would go to the LabVIEW forum. Unless your question is about Measurement Studio and Visual Basic or C++? It's a little confusing from your posts what programming language you are using.
Zofia
(3,742 Views)
I am using LabVIEW code
(3,740 Views)
Thanks for clarifying, as I said earlier, you should post on the LabVIEW forums. Measurement Studio is a different product used for text-based analysis.
You can find the LabVIEW forums here:
https://forums.ni.com/t5/LabVIEW/bd-p/170
Zofia
(3,737 Views)
