Too long runtime on AnalogMultiChannelReader.ReadMultiSample with NationalInstruments
When I use this method ReadMultiSample in ReadCcv and ReadOcv its take more then a second of run time.
I think its too long What can I do to make it run faster?
My controller class
class Controller
public AnalogMultiChannelReader reader;
public bool TaskIsRunning { get; set; }
public double Current_ { get; set; }
public double dTime_ { get; set; }
public Single Ocv_ { get; set; }
public Single Ccv_ { get; set; }
public long OcvtaskHandle { get; set; }
private MessageBasedSession mbSession;
Task CcvTask;
Task OcvTask;
~Controller()
CcvTask.Dispose();
OcvTask.Dispose();
public Controller() {
CcvTask = null;
OcvTask = null;
public double ReadCcv()
// Create a new task
double frequency = 50000;
double TimePerPoint = (1 / frequency);
int numSampsPerChannel = (int)((dTime_ / 1000.0) * frequency) + 95;
if (CcvTask == null)
InitLoad();
// Initialize Local Variables
double rangeMinimum = Convert.ToDouble(GlobalVariables.rangeMinVolt);
double rangeMaximum = Convert.ToDouble(GlobalVariables.rangeMaxVolt);
CcvTask = new Task();
CcvTask.AIChannels.CreateVoltageChannel(GlobalVariables.voltageSorceInput, "",
(AITerminalConfiguration)(-1), rangeMinimum, rangeMaximum, AIVoltageUnits.Volts);
CcvTask.Timing.ConfigureSampleClock("", frequency, SampleClockActiveEdge.Rising,
SampleQuantityMode.FiniteSamples, numSampsPerChannel);
CcvTask.Triggers.StartTrigger.ConfigureDigitalEdgeTrigger(GlobalVariables.triggerSorcePort, DigitalEdgeStartTriggerEdge.Rising);// ReferenceTrigger.ConfigureDigitalEdgeTrigger(
CcvTask.Control(TaskAction.Verify);
try
AnalogMultiChannelReader reader = new AnalogMultiChannelReader(CcvTask.Stream);
SendSCPI("PROG:STAT RUN");
double[,] x = reader.ReadMultiSample(numSampsPerChannel);
string res = "";
return x[0, numSampsPerChannel - 90];
catch (DaqException exception)
//startButton.Enabled = true;
//myTask.Dispose();
throw exception;
public bool GetFootSwitch(){
Task myTask = new NationalInstruments.DAQmx.Task();
myTask.DIChannels.CreateChannel(GlobalVariables.footSwitchPort, "FootSwitch",ChannelLineGrouping.OneChannelForEachLine);
DigitalSingleChannelReader reader = new DigitalSingleChannelReader(myTask.Stream);
bool val = reader.ReadSingleSampleMultiLine().First();
return val;
public void BeepOk(int Periode=600){
Task myTask = new Task();
myTask.DOChannels.CreateChannel(GlobalVariables.beepPort, "beep",ChannelLineGrouping.OneChannelForAllLines);
DigitalSingleChannelWriter writer = new DigitalSingleChannelWriter(myTask.Stream);
writer.WriteSingleSampleMultiLine(true, new bool[]{true});
Thread.Sleep(Periode);
writer.WriteSingleSampleMultiLine(true, new bool[]{false});
public double ReadOcv()
int numSampsPerChannel = 1000;
int numChannels = 1;
List<double> data = new List<double>();
string x = "";
int arraySizeInSamps = numSampsPerChannel * numChannels;
if (OcvTask == null)
OcvTask = new Task();
OcvTask.AIChannels.CreateVoltageChannel(GlobalVariables.voltageSorceInput, "", (AITerminalConfiguration)(-1), rangeMinimum, rangeMaximum, AIVoltageUnits.Volts);
OcvTask.Timing.ConfigureSampleClock("", numSampsPerChannel, SampleClockActiveEdge.Rising, SampleQuantityMode.FiniteSamples, 101);
data = new List<double>(arraySizeInSamps - 1);
AnalogSingleChannelReader r = new AnalogSingleChannelReader(OcvTask.Stream);
data = r.ReadMultiSample(numSampsPerChannel).ToList();
return data.Average();
private void SendSCPI(string text)
mbSession.BeginWrite(text + "\n");
public void InitLoad()
ResourceManager rmSession = ResourceManager.GetLocalManager();
mbSession = (UsbSession)rmSession.Open("USB0::0x0B3E::0x1004::ND002613::0::INSTR", AccessModes.NoLock, 10000);
SendSCPI("PROG:FSP:END 10");
SendSCPI("PROG:FSP:TIME 0.0001");
SendSCPI("PROG:NAME 11");
for (int j = 1; j <= 10; j++)
Thread.Sleep(5);
SendSCPI("PROG:FSP:EDIT " + j + "," + (Current_/1000).ToString("#0.000") + ",1,1");
SendSCPI("PROG:LOOP" + dTime_);
// This routine reads the string returned by the instrument
private string GetSCPI()
string ret = mbSession.ReadString();
return ret.Replace("\n", "").Replace("\0", "");
public void initFluke(){
mbSession = (SerialSession)rmSession.Open("asrl3::instr",AccessModes.NoLock,10000);
((SerialSession)mbSession).BaudRate = 115200;
((SerialSession)mbSession).FlowControl = 0;
((SerialSession)mbSession).Parity = 0;
My main class :
class Program
static Controller controller = new Controller();
static void testRun() {
double ocv = controller.ReadOcv();
double ccv = controller.ReadCcv();
static void Main(string[] args)
controller.dTime_ = 100;
controller.Current_ = 5000;
testRun();
testRun();
testRun();
testRun();
testRun();
Console.ReadLine();
(3,165 Views)
Hi Shazoom,
This is likely an issue with how you are configuring your sample clock. Check out the forum post below and consider working on your sample timing.
https://forums.ni.com/t5/Measurement-Studio-for-NET/Slow-measurement-with-cDAQ-9174-and-NI-9208/td-p...
I also notice you are calculating and casting to a list in line with your measurement. You may want to look into the computing resources associated with that. Lastly, next time you post code on the forum I would highly recommend keeping the formatting and adding code documentation. It is difficult to sift through undocumented code.
Good luck!
Clint T.
(3,132 Views)
