Toolbox appearance on Image Viewer
Is there a way to change the appearance of the tools on an image viewer? I dont ncessarilly need the ROI to change, but I do want to be able to change the appearance of the tool in the toolbox.
(4,457 Views)
I am not 100% sure what you are asking about,  Would you like to change the The Icon in the toolbox? If you could use a screenshot and explain what you want to change that would help me.  Thank you.
(4,441 Views)
So,when you add a rectangle tool, to the viewer tools. the toolbar appears like in the attached. I'd like to replace the rectangle tool with another image?
Is there a way to add tooltips to these tools/
(4,439 Views)
Hi uk1980,
Unfortunately, you cannot change the appearance of the tool icons in the ROI toolbar. At most, you can select which tools you want to be visible under the "ToolsShown" propery of the image viewer.
(4,413 Views)
