Trigger Restart example
Hello Wallace,
Should I calculate SampleClockPeriod using the following equation
SampleClockPeriod = 1 / SamplingRate ?
Thanks a lot,
JSInc
Message 11 of 15
(2,079 Views)
Hi JSInc,
You are correct.  SampleClockPeriod = 1/SampleClockRate.
Best wishes,
Wallace F.
Message 12 of 15
(2,064 Views)
Hello Wallace,
Is Sampling Rate different from Sample Clock Rate? I am using S-series card PXI-6123 sampling at 500k samples/second.
Thank you,
JSInc
Message 13 of 15
(2,051 Views)
To answer my last question, I did a few tests, it seems the Sample Clock Rate is the same as the on board time base, which is 20MHz for PXI-6123.
JSInc
Message 14 of 15
(2,047 Views)
Hi JSInc,
The terms sample rate and sample clock rate can be seen as synonymous since one sample (per channel) is acquired with every designated edge of the sample clock.
Best wishes,
Wallace F.
Message 15 of 15
(2,023 Views)
