Trouble Writing to Digital Channel Line
Hello:
I am developing a C#/.NET that uses DAQmx 9.4 to communicate with a NI 6015 DAQ Pad.
When I try to write to several digital channel lines at a time, an error message is returned:
            var digitalWriteTask = new Task();
            digitalWriteTask.DOChannels.CreateChannel("Dev1/Port0/line0"string.Empty, ChannelLineGrouping.OneChannelForAllLines);
            digitalWriteTask.DOChannels.CreateChannel("Dev1/Port0/line1"string.Empty, ChannelLineGrouping.OneChannelForAllLines);
            digitalWriteTask.DOChannels.CreateChannel("Dev1/Port0/line2"string.Empty, ChannelLineGrouping.OneChannelForAllLines);
            var dataArray = new bool[3];
            dataArray[0] = true;
            dataArray[1] = false;
            dataArray[2] = false;
            var writer = new DigitalSingleChannelWriter(digitalWriteTask.Stream);
            writer.WriteSingleSampleMultiLine(true, dataArray);
            // The following error is returned when the writer.WriteSingleSampleMultiLine method executes:
            //Write cannot be performed, because the number of channels in the data does not match the number of channels in the task.
            //When writing, supply data for all channels in the task. Alternatively, modify the task to contain the same number of channels as the data written.
            //Number of Channels in Task: 3
            //Number of Channels in Data: 1
            //Task Name: _unnamedTask<0>
            //Status Code: -200524
 I was also wondering if it is possible to write to a digital line individually using a logical line name (instead of having to write to all lines at the same time using an array)?  If so, can you please provide a code example?
Thanks for your assistance.
Chris
(4,462 Views)
Try using this
digitalWriteTask.DOChannels.CreateChan​nel("Dev1/Port0/line0:2", string.Empty, ChannelLineGrouping.OneChannelForAllLines);
Curt
(4,444 Views)
